Page 108 of 149 FirstFirst ... 85898106107108109110118 ... LastLast
Results 1,071 to 1,080 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1071
    Apr 2013
    Helsinki
    It still sounds like a bug rather than a feature. Based on my quite limited total driving time with the new unit the RDS itself works just fine and it is indeed useful feature as the same stations with same names are available on different frequencies around the country here. The receiver also works quite well with the antenna adapter/amplifier as it finds several frequencies for each station easily and I have not really experienced any static. Anyway this one is not that much of a problem.
    What I really dont't like is that changing from FM1 to FM2 and FM3 has to be done through pressing first Band and then FM and then the same again and again on touch screen while there is this RADIO hard button, which according to user manual scrolls through FM1, FM2, FM3 and AM if pressed repeatedly. Only that it does not.
  2. #1072
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Hans Byxor View Post
    Yes and no. The bug is that if it cannot find another station with the same name, it should go back to the frequency it was on rather than dropping to the no 1 preset on the band.
  3. #1073
    Dec 2012
    Michgan, USA
    I wanted to give an update on my reverse camera issue. As you recall, I have an ANS-810 and bought a boot handle reverse camera off Aliexpress. I initially connected the camera directly to the right rear reverse light power line. It didn't work. After consultation here, I re-wired the set-up to use a relay and now the camera is wired to get power derived from the rear 12V power outlet which I spliced into. I still don't have any reverse camera activity. I also don't have any power to my right rear reverse light. This happened prior to the rewiring to use the relay.
    I'd like to determine which fuse is responsible for the right rear reverse light. This would be for a US vehicle. Also, here is a crude drawing showing how I wired the relay. I think this is fine but want to make sure I haven't done anything wrong. I do think something has happened to the OEM power feed line to the rear reverse light since it doesn't have any voltage going to it when I place the vehicle in reverse (confirmed with multimeter). Any thoughts would be appreciated.
    Paul.
  4. #1074
    Jan 2012
    Epping, NSW
    are you sure Brown is ground?
  5. #1075
    Pacific Paradise QLD
    I would have run Ground off the relay to a body bolt to be absolutely sure as sometimes the brown wire could go across to the other side light and from there to ground
  6. #1076
    Jan 2012
    Epping, NSW
    the relay is probably fine to go across the light ( brown& blue, only if the light drops sufficient load across it in operation), but the camera should probably go to the body for ground, in case there is some other funky monitoring stuff going on in that brown wire.
  7. #1077
    Dec 2012
    Michgan, USA
    I'll move the relay and camera grounds to a body bolt tomorrow (already night here) and report back. The rear light plastic housing has some bolts attaching them to the body if I recall from my working through the little panel inside the car. Would this suffice as a site for grounding?
    Paul.
  8. #1078
    Jan 2012
    Epping, NSW
    scratch a bit of paint off so the wire is contacting bare metal.
  9. #1079
    Quote Originally Posted by tonymy01 View Post
    Try and get a bolt that goes through metal and into metal Going through plastic its hard to get it tight enough to get a perfect contact.
    Also you want one that you arent going to remove again anytime soon
  10. #1080
    Dec 2012
    Michgan, USA
    Will do. Thanks for the advice.
    Paul.
