Page 104 of 149 FirstFirst ... 45494102103104105106114 ... LastLast
Results 1,031 to 1,040 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1031
    Jun 2011
    Quote Originally Posted by richmurphy View Post
    As the screen resolution is identical (800 x 640) for both models, would that mean the smaller screen will actually look nicer? Same number of lines over a smaller area being my logic but please correct me if I'm wrong.
    Technically yes but you can't identify individual pixels either way from the driver seat. This isn't a phone that you hold close to your face, so the bigger screen makes more sense - why waste pixels that you can't see? Bigger size in a car environment can only be bad if you can identify visual flaws.
    I have owned both a 6.5 inch unit and my current ANS 810 and I can tell you I would never go back to a smaller screen. The only reasons I would not recommend the 810 are when a customer really does not like the design as a matter of personal taste and when they really want to stick close to OEM.
  2. #1032
    For me i would say all depends on personal preference and of cause btw this two model 510 looks more close to the stock unit
  3. #1033
    Mar 2013
    UK
    Quote Originally Posted by wai View Post
    Where did you attach the GPS antenna?
    Have you checked to see if the antenna connector has not come loose?
    its tucked under the centre vents, its been fine up until a week ago.
    where do other people have theres?
    i've checked the connections and they're all fine.
    Quote Originally Posted by DkN View Post
    Perform a full firmware flash and then so another GPS reset, if that does not work then something is wrong with either the antenna cable or the hardware.
    i don't have the firmware to flash with, the seller has told me to move the antenna to somewhere above the dash. the only place i can see that won't look rubbish is behind the rearview mirror, what do you think?
    thanks.
  4. #1034
    Jun 2011
    Sydney NSW
    Quote Originally Posted by a803sgo View Post
    When I fitted mine (Caddy Maxi Life), there was a vertical surface just to the left of the opening where the unit went. I glued mine to that surface.
    Oh yes, the excess cable should be wound into a figure of 8 pattern and kept like this with cable ties. If you wind it it, it will act an an antenna itself and not necessarily pick up the GPS signal.
  5. #1035
    Sep 2008
    Melbourne, Australia
    I had mine mounted in the dash, behind the mirror and now just on top of dash in the very corner at bottom of windscreen. Found best signal there. Looks OK too.
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  6. #1036
    Just checking but is this the latest version for the ans810?
    If not may I please have the upgraded firmware. I should be a subscriber to your firmware updates
    Thanks!
  7. #1037
    just wondering. with the forthcoming new and improved head units. is there any upgrade on the preamps or sound output?
  8. #1038
    Quote Originally Posted by chillybone View Post
    Thanks!
    Appreciate you can share what's the problem of this version on your ANS 810. Thanks in advance
  9. #1039
    key dkn do they have a unit for the vw cc yet 2009? i already own the ans810 but wanted to upgrade and what is the name of it?
    i also have been having a problem with my ipod hook up, there is a static or ticking noise alol the time in the background of a song that has been happening for awhile. (used it with a iphone 4s and iphone 5 as of now.)
    and i was wondering if the bluetooth audio on the new unit would be better quality because i origionally bought this unit for that but the quality was so bad ive been using the ipod cord instead.
    are there any signifiacnt changes between the new unit and the ans810 that is worth upgrading?
    and if you can ship to the US i would prefer to deal with you
    This was my problem but was skipped lol.
    iPod audio has background noise. Ticking sound with wind almost.
  10. #1040
    Jun 2011
    I've heard a couple of isolated BT / iPod audio issues but these seem to be faulty units, for me and most of my customers there's no background noise.
    M99 is the latest firmware now, I will be sending it out in the next few days, just need to update the instructions relating to MCU.
    Other than OEM inputs at the back of the unit and the CPU / RAM change I don't know about the status of other hardware updates. I'm pushing them for the preamps but it's not something that customers in China really pay attention to so without requests they wouldn't see a need to upgrade. Going up to 4V would require an upgraded DSP chip.
    From what I understand though the current 2V preamps sound pretty good as they are (nothing mind blowing but definitely better than OEM), and there is debate as to whether 4V or higher would really make a difference in a car environment full of metal.
