Page 103 of 149 FirstFirst ... 35393101102103104105113 ... LastLast
Results 1,021 to 1,030 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1021
    Mar 2013
    Amman - Jordan
    Hello Sandy, while waiting for the new units i have started to think that the ANS810 buttons being on top is not OEM style so am thinking more about the 510-610 units now. i assume all have the same HW and SW and the only difference is screen size, right?
    Thanks
  2. #1022
    Mar 2013
    UK
    Quote Originally Posted by DkN View Post
    Did you perhaps perform a firmware upgrade recently? Sometimes this can happen. Try resetting the iGo software by deleting the folder named "save" on your GPS SD.
    reset did nothing, gps is still poor.
    any other ideas?
    thanks.
  3. #1023
    Jun 2011
    Sydney NSW
    Quote Originally Posted by a803sgo View Post
    my unit has been working great but over the last few days the gps signal has been very flakey, sometimes i never get a signal, sometimes i get a signal after 20 minutes and other times after exiting igo and going back in a few times and then waiting a few minutes it finds a signal.
    it used to be that it would have a signal as soon as the car was started, i've not changed anything and still park in the same places that i did when the signal was instant.
    any ideas?
    Where did you attach the GPS antenna?
    Have you checked to see if the antenna connector has not come loose?
  4. #1024
    Dec 2012
    Quote Originally Posted by Na2eL View Post
    I was quite happy with the look of the ANS810 until you said that. Now I'm in two minds.
  5. #1025
    Jun 2011
    All the units within the same series have identical hardware across the different models.
    The knobs need to be on top for the 8 inch model because it's more narrow at the bottom. It still looks perfectly stock when installed, but those more familiar with VW would obviously be able to tell that's not an OEM model. There are a few pictures of the 810 installed in dash from this thread if you scan through the first 10 pages or so.
    any other ideas?
    thanks.
    Perform a full firmware flash and then so another GPS reset, if that does not work then something is wrong with either the antenna cable or the hardware.
  6. #1026
    Mar 2013
    Amman - Jordan
    100% true. its all personal reference, i would love the 8" screen in my dashboard but again i always try to stay as near to OEM as possible.
    Quote Originally Posted by richmurphy View Post
    Sorry for this, my bro did it with me and now i did it to you
  7. #1027
    Special complimentary pics as your reference:-
    ANS 510 on Golf TSI MK6
    ANS 810 on Golf GTI MK6
  8. #1028
    Mar 2013
    Amman - Jordan
    Quote Originally Posted by Alex lee View Post
    AN810 looks better
  9. #1029
    Dec 2012
    As the screen resolution is identical (800 x 640) for both models, would that mean the smaller screen will actually look nicer? Same number of lines over a smaller area being my logic but please correct me if I'm wrong.
  10. #1030
    Mar 2013
    Amman - Jordan
    you can calculate the PPI:
    Display Dimensions Calculator
    and yes it should look better.
