Page 99 of 149 FirstFirst ... 4989979899100101109 ... LastLast
Results 981 to 990 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #981
    Aug 2012
    United States
    Quote Originally Posted by riggsy View Post
    Yeah, I've exactly the same problem no matter which brand/size of card I use, I've logged this issue with Audiosources and mentioned to DKN, very frustrating, just hope they look into fixing.
    Well, I swapped out for a different card with a fresh format before loading my music files and even though it's the same size (32GB) it works perfect without any errors! Maybe the unit just has issues communicating with some cards. In the unit's defense, the card had some errors when I put it in my computer too. So I'll chalk this up to the card and not the ANS-810.
  2. #982
    Apr 2013
    Wisconsin
    I'm interested in the 710 or may wait for the new unit, I have a 2007 GTI MKV and after reading the entire thread have a few questions
    Does ANS-710 fit in GTI.. I assume it does but AudioSources website only lists it with the Toureg?
    Does a MKV have a GPS antenna coming from the shark fin? It seems everyone wires up the antenna that comes with the unit and I have no probs with that, but if there is an existing GPS antenna in the shark fin that seems like it would be the best. MKVs with a factory nav unit must use the shark fin as they don't have an indash antenna?
    Does the backup cam work in a MKV
    What is the resolution of the 7"?
    Anyone run TomTom or American Users where do you buy iGo Software and Maps, looks like it only runs on Iphone from website? It looks like if you buy from this guy or AudioSources you get maps and software (depending on what country you are in)
    ODB Functionality.. does that allow you to see your CEL Check Engine Light Codes and Clear them or do you still need a VAGCOM tool for that?
  3. #983
    Jun 2011
    Quote Originally Posted by JasonTheLucky View Post
    The 710 is for the Touareg and will not fit in a Golf. The 7" Golf version is the ANS-610.
    I'm not entirely sure if having a shark fin automatically means you have the GPS aerial, but if you had factory navigation, then yes the shark fin would have the GPS aerial. If so you can use a FAKRA to SMA adapter and connect it to the unit. Alternatively, wait for the new unit and it will have stock FAKRA connections.
    There are reverse cameras to suit Golf 5, you can choose LED licence plate type or the VW badge type camera.
    The OBD can read and clear DTCs but in my experience with most fault code readers they may not be able to read all fault codes. I don't think it can clear a CEL - it's not a replacement for VCDS, it's more used to show additional info and do acceleration & fuel consumption calculations.
  4. #984
    Adelaide hills, SA
    It could be handy to have in the first post the latest fw. for each unit.
    Just chasing what's the latest fw for the ANS710?
  5. #985
    Jun 2011
    I'm near the character limit for the first post so I haven't been doing much with it. Once the new unit is released I will start a new thread for that and clean up some info in this thread to match.
    The latest M version firmware is M94-01-09. V version is V95.
    In some unrelated news, I just discovered today that a Golf 5 climatronic upgrade to the Golf 6 version does indeed activate AC display on the ANS head unit.
    One thing I did overlook with the climatronics is that I bought mine from the US and the driver / passenger controls are swapped around but I never use the dual zone function so it's not too bad.
  6. #986
    Mar 2013
    Amman - Jordan
    Quote Originally Posted by DkN View Post
    Thanks for the update
  7. #987
    Mar 2013
    Sunshine Coast, QLD
    I'm quite interested in one of these units, but I just want to ask if the iGo software is customisable with regards to themes, and how easy they would be to install? One of the main reasons for not pulling the plug on one of these is I just find the iGo software super ugly, and wouldn't want to have to look at that all the time. Has anyone created a "Golf" theme for the nav software?
    Thanks!
  8. #988
    Apr 2013
    Still Waiting Patiently
    You know as much as I know at this stage, Audiosources is hard at work preparing for the HK electronics fair at the moment which happens in the middle of this month. They may plan to debut the new unit then, but either way we can only wait now.
    Unless I misunderstood, it looks like they didn't announce the new unit at that fair?
  9. #989
    Aug 2011
    Try swapping it in the CANBUS with VCDS. I has a LHD CANBUS and had to swap it to RHD. Should work opposite for your situation.
  10. #990
    Jun 2011
    Quote Originally Posted by Flying Ace View Post
    Thanks!
    It's easy enough to get skins for iGo, and I include a few more popular user-created ones with the GPS SD. Which iGo are you talking about though? Maybe you're thinking of iGo 8. iGo Primo 2 may not be the fanciest default interface out there but it's functional and I definitely wouldn't call it ugly.
    I don't know of any Golf or VW specific themes made but who knows I might give that a go if there is demand and I have time. Installing a skin is as easy as copying the skin's zip file into the skins directory and choosing it in iGo settings.
    Quote Originally Posted by PMinAU View Post
    The fair is still underway, why do you think they haven't announced it? They are currently showing off a Touareg RNS-850 replacement running the new hardware + software. They're still not giving a concrete release date though, I think they want to get the software to be more stable and bug-free before releasing this time. And so far, unless you're physically at the fair, no one has seen the software yet.
    Quote Originally Posted by lankfert View Post
    Thanks mate but I'm in Australia too Issue is with the programming / wiring within the climatronics unit itself because it's a US LHD model. My CAN-Bus has always been RHD, and so has my old climatronics unit. I'll survive with turning the knob on the left instead of the right to adjust the AC.
