Page 98 of 149 FirstFirst ... 488896979899100108148 ... LastLast
Results 971 to 980 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #971
    Jun 2011
    FAT also has file limits in the root folder, something like 512 files.
    The size if the card shouldn't matter, more so the size of your content and how many music files you have. You could try reformatting your card and copying the music back. You could also try reflashing the MCU. You can't flash the same version as you currently have, so flash to an older version and then flash back to the current version. Do this without the card in your media slot, and insert it back after you finish flashing and the unit has booted into radio. Remember an MCU flash resets your radio stations and equaliser settings.
  2. #972
    Apr 2011
    Re: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
    Hi Sandy,
    I'm having the same issue. Any new updates or resolution?
    Quote Originally Posted by bazzle View Post
    I have sent videos to Audiosources. Sometimed the rev cam comes up, sometimes it needs a 2nd go, sometimes it doesnt.
    If you put straight into rev when you start off the gps doesnt always fire up. Its something to do with the interaction between the 2 processors I reckon.
    If your saying there are no issues now what version is that please?
    Sent from my Nexus 4 using Tapatalk 2
  3. #973
    Jan 2013
    Melbourne Vic
    Quote Originally Posted by DSGVW View Post
    Hi Everyone,
    I know this has been discussed before but not sure if a solution was found. My ANS-810 has a hard time reading my 32GB SD card. Some days it reads just fine, others it says "BAD SD" and others it loads but then says the track is 12:15-12:15 and nothing plays and no menus/folders are available. It used to happen every other day, now it is most every drive. If I pop the SD card out or restart the radio, or switch from radio back to SD usually i can get it to go but some days it takes a combination of all these or 2-3 resets of the device. Then it picks up like nothing ever happened. Is my card going bad? Maybe I will try a new one or smaller one and see what effect that has.
    Just wondering if anyone with a similar experience can chime in.
    Thanks!!
    I have similar issues with a 16GB SD card formatted with FAT32. Works fine most of the time, but if I remove the card to add tracks etc, it takes a few goes slotting it back in before the unit recognises it and can read it. I also get the 12:15-12:15 error regularly and have to power cycle the unit to clear it. It is a good idea to try out a different SD card to be sure, but my feeling is that it is not necessarily a problem with your card as several others have mentioned having the same issues. I am patiently awaiting new firmware to hopefully resolve these intermittant but annoying issues.
  4. #974
    Jun 2011
    Quote Originally Posted by turbo81 View Post
    Hi Sandy,
    Please read my previous posts on the issue, as I said I have many customers with RVC and they don't have this issue - I would need to know more details e.g. did you use a relay switch, have you tested the connection etc. The software is designed so that as long as there is a feed in the RVC slot, the RVC image will override everything else. So if you have intermittent issues, the cause would be the RVC signal. It's possible for the hardware to be faulty in detecting the signal but the most likely cause by far is the wiring.
    Quote Originally Posted by enigma32 View Post
    I think this issue has to do with the unit's memory of last song played - you may have noticed the memory sticks even after a full firmware flash. Similarly if you changed the contents of the SD card, the memory may not change and could get corrupted. This is why I recommend a MCU flash (which clears the other media settings) with your SD card out of the media slot. After MCU flash is complete and your unit boots into radio, THEN insert the card again and it should start its song memory from new.
    I've raised the issue with Audiosources but as I said the recent weeks they have been focused on the new unit so any updates would come some time after the new unit is released. By then they could also have a long list of things they need to do and this particular fix may or may not happen in the next firmware release. I will be pushing for results best as I can, as always.
  5. #975
    Sep 2008
    Melbourne, Australia
    Quote Originally Posted by DkN View Post
    Its not hardware related, at least in my case. I am currently conversing with Audiosources and they are making me up a new update to try to improve the issue.
    Im guessing a lot of your customers just havent recognised the issues as such or havnt posted here again.
    I will post my outcomes if any in a later post.
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  6. #976
    Aug 2012
    UK
    Hi Everyone,
    Thanks!!
    Yeah, I've exactly the same problem no matter which brand/size of card I use, I've logged this issue with Audiosources and mentioned to DKN, very frustrating, just hope they look into fixing.
  7. #977
    Jul 2012
    What's going on with these new units??
  8. #978
    Mar 2013
    Amman - Jordan
    Quote Originally Posted by SARIS View Post
    +1
  9. #979
    Sep 2008
    Quote Originally Posted by Na2eL View Post
    +1
    The electronics show is still on in HK where they are to be released.
    Baz
  10. #980
    Dec 2012
    melbourne
