Page 96 of 149 FirstFirst ... 46869495969798106146 ... LastLast
Results 951 to 960 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #951
    Jun 2011
    The brown back conn wire is a recent addition, it began about 2 months or so ago.
    Not sure what you're saying about what you have done and tested but if you're saying the reverse camera not showing up / being glitchy is due to the firmware, that's not likely to be the case. There was one version from October that prevented the RVC from displaying but that was fixed in the next release.
    As I said issues with powering the camera directly from the reverse wire has been documented on this forum before, with aftermarket install of the OEM camera connected to RNS/RCD 510. It has nothing to do with the ANS unit.
  2. #952
    Sep 2008
    Melbourne, Australia
    I have sent videos to Audiosources. Sometimed the rev cam comes up, sometimes it needs a 2nd go, sometimes it doesnt.
    If you put straight into rev when you start off the gps doesnt always fire up. Its something to do with the interaction between the 2 processors I reckon.
    If your saying there are no issues now what version is that please?
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  3. #953
    Jun 2011
    Quote Originally Posted by bazzle View Post
    That sounds more like a wiring issue. You mentioned you put in the wire yourself, how certain are you that it's making proper connection? Also that wire is supposed to run on different MCU.
    If you connect your camera to a permanent stable 12V source you can confirm if there's a problem yourself. Just manually connect / disconnect the 12V source to see if power source is indeed the issue, the unit will switch to RVC whenever signal in its reverse cam in source is detected, regardless of what screen your unit is on.
  4. #954
    Sep 2008
    The same issue with variations has been present on a couple of updates. Audiosources confirmed it.
    I am confident of my abilities to modify simple connectors and the like. One of my prevoius backgrounds was in electronic hardware.
    Camera has been tested previously on straight 12v source.
  5. #955
    Jun 2011
    There still remains the issue of possible wrong MCU, if you are 100% confident with the wiring. Remember you are talking with sales staff when you talk to Audiosources and they may not always know the answer. I have many customers with RVC, no one ever said anything about the RVC sometimes not starting up in reverse. There is no second processor to conflict with, the ANS uses the one ARM11 CPU for all operations.
    GPS not firing up when you go straight into reverse is possible, but for different reasons. I assume by GPS not firing up you mean the unit itself. Sometimes going straight into reverse the unit itself does not fire up until you are out of reverse. It has to do with the function of seeing the reverse camera even when the unit is not powered on and you are in reverse. There's a slight delay when you start the car before the unit is powered on, and if you go quickly into reverse the unit may not realise it is powering on yet and think it's in reverse camera only mode. It would then show you the camera without starting the unit.
  6. #956
    any news on the new head units. audiosourced just posted in the touareg forums they have the new units in stock now
    volkswagen touareg autoradio gps dvd navigation system
    are these it?
  7. #957
    Jun 2011
    Quote Originally Posted by chocolatemoose View Post
    are these it?
    Do you have a link to that post?
    AFAIK they only have test stock at the moment, but yes the Touareg 2010+ unit is the first of the new units and the one they are fine-tuning / experimenting on.
    That link is not the right unit, it's not Audiosources at all. Forgetting the fact that I mentioned the new unit would have Dual Core Cortex A9 1.2Ghz CPU, why would Audiosources take a step backwards with a generic rather than OEM UI?
    Also, the Touareg 2010+ unit is the RNS-850, you can Google some images to see what it looks like.
    The news for the finalised release date is still being tightly sealed. As I said though they will be attending the HK Electronics Fair from 13 April and some news will be realeased then.
  8. #958
  9. #959
    thats kinda nice to hear. when i saw this new unit i though. hmm ok yeah its a bit better but didnt look GREAT.
  10. #960
    Jun 2011
    Yup, that's definitely not Audiosources. They don't have a US distributor yet. But I suspect things are going to change very quickly once the new unit is released
