Yes if you use the brown back conn wire then you wouldn't need a relay, since that wire is designed to directly power the camera.
Regarding the reversing lines, in later firmware there are two sets both stationary and dynamic, they've done this because this is how it looks on the RNS-510. Personally I don't see much point in keeping the stationary lines, but I guess you can then see where you'll go if you straighten up?
