![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
schultp
I'll convert to a relay set up. But, would the lack of a relay set up really lead to it not working?
Paul.
Yes, the reverse light power is monitored by the CAN-Bus and may or may not respond well to a direct power tap. It varies from car to car (works for some, doesn't work for others) but issues with directly tapping the reverse light generally on VW vehicles have been previously documented. If you want to know the specifics, I believe it has something to do with the reverse light signal being a pulse signal.
The OPS coming up by itself is interesting though, I've not heard of that happening. The OPS can function without the reverse camera so theoretically it shouldn't be affected by the RVC, however it's possible that the software has a failsafe that if for some reason if the OPS did not switch on when it's supposed to, it will still switch on if power is supplied to the RVC. This would mean an unstable power source that perhaps feeds a little bit of power to the camera when not in reverse could trick the OPS into turning on.
