Page 93 of 149 FirstFirst ... 43839192939495103143 ... LastLast
Results 921 to 930 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #921
    Mar 2013
    Greece
    @DkN
    Because I'm interesting to purchase the ANS-610, I want to ask if there is any drain battery issue when installing ANS series in MKV GOLF or JETTA earlier than 06/2006 model. These models they have stock unit RCD 300/500 and if you install RCD 310/510 there is definitely drain battery issue because of the older can bus. These cars they use the type 1 steering wheel buttons like the picture below.
    So i need to be 100% sure before i make the order.
    Thanks in advance
    Alexis
  2. #922
    Adelaide hills, SA
    I'm not sure if anyone would give you 100% guarantee, but, you shouldn't have the battery drain issue with that unit.
  3. #923
    Jun 2011
    As I mentioned in the first post there will be no battery drain whatsoever.
    The unit has been installed on older Golf and Jettas with half screen MFD without any issues.
  4. #924
    Mar 2013
    Amman - Jordan
    DkN, if i switch my current climate controls in my 2008 R32 to the MK6 one, will it work with the ANS810 or the new units?
    Thank you,
    Na'el
  5. #925
    Sep 2008
    Melbourne, Australia
    I cut out a matte screen protector from an ipad piece I had laying around. Works "OK" for me.
    Give it a go and if you dont like it , remove it. Easy to play with.
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  6. #926
    Jun 2011
    Quote Originally Posted by Na2eL View Post
    Thank you,
    Na'el
    The climatronics replacement is just a drop in, it doesn't change the fact that your CAN-Bus does not store air con information. You'd have to change your CAN-Bus to mk6 for it to work, though I don't know of anyone who's done that so I don't know if there are other consequences for doing that.
  7. #927
    Mar 2013
    Greece
    I just made the order for the ANS-610 directly from AS since I'm from Greece, I hope i don't have any compatibility problems
    Can somebody give me the exact measures of the LCD screen so i can order an anti-glare film from Quality Screen Protectors for Any Display by Clarivue
    Thanks in advance
    Alexis
  8. #928
    Jun 2011
    Quote Originally Posted by rivol View Post
    Thanks in advance
    Alexis
    I don't have an ANS-610 with me but you can just measure it when it arrives, maybe you'll even be okay with it without a screen protector.
    You shouldn't have any problems with compatibility, the unit is more designed for European variants than US anyway.
  9. #929
    Mar 2013
    Greece
    OK, I was just wanted to be ready, it will take some time to arrive and would be easier to do this job on the desk before I install it.
    Thanks anyway
  10. #930
    Mar 2013
    Amman - Jordan
    Thanks DkN.
    another question please, will any of these units fit old cars? am asking about Skoda Fabia 2001
