Originally Posted by
a803sgo
thats the answer i was looking for, thanks.
i'm not using a rvc, just a normal reverse camera so i can wire it directly to the revser lamp? i don't need the back con connection?
i first try powering the antenna amp with the 2 blue wires like dkn if not i'll get the right one!
thanks for the help.
The back conn is to save you time and effort, tapping the reverse light is usually the most difficult part of an RVC installation because most cars have the reverse light on the boot lid. Also on many VWs it's not enough to just tap the reverse light, you will need to use a relay switch. None of this will need to be done if you use the back conn wire, which can directly power the camera.
By the way I don't know what you think RVC stands for, but it just means reverse camera.
Also I think wai was talking about the FAKRA connectors not the power wire. If the power wire in your replacement antenna doesn't match the connector on the end of your blue wire, that's not a big deal and you can just join them whatever way you like as long as they make proper contact. If the FAKRA connectors are the wrong type though, you should probably avoid forcibly joining them because it could affect your signal.
