Page 87 of 149 FirstFirst ... 3777858687888997137 ... LastLast
Results 861 to 870 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #861
    Jun 2011
    Quote Originally Posted by DSGVW View Post
    When is the next firmware due out? I am so sick of looking at the reversing screen even though i have no backup camera or sensors AND it shuts the audio off.
    I'm not sure but I just said you can flash the previous MCU to stop this behaviour, in the post you quoted.
  2. #862
    Oct 2012
    Newcastle NSW
    Gosh if that pisses you off you must spend a lot of time in reverse!
  3. #863
    i wonder if the factory parking lines will turn with an after market rear view camera
  4. #864
    Mar 2012
    Quote Originally Posted by chocolatemoose View Post
    Yes they do. Not sure about use of the word 'factory'. The ANS head unit generates lines off the canbus info.
    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
  5. #865
    Jun 2012
    Will their be an upgraded/new version available for the Touareg?
  6. #866
    Jun 2011
    Quote Originally Posted by whiskywallah View Post
    Yup, I've always wondered about VW's decision to build an entire module that costs hundreds of dollars when the steering sensor info was available to be read from the CAN-Bus all along.
    Quote Originally Posted by tom_12_24 View Post
    The new platform will be rolled out across all models, but beginning with the more mainstream Golf / Passat etc model.
  7. #867
    Feb 2013
    Byron Bay, NSW
    I have a 2004 Audi S4 with the RNS-E and Bose stereo, will one of your 8” Screen units fit this car. I am not sure if the CANBUS is compatible as i know the new RNS-510 and MMI units are incompatible.
    I am looking to ditch the RNS-E but i don’t want to go for a screen smaller than 8” and also want to keep the OEM look so the usual double din head units won’t work either.
  8. #868
    Jun 2011
    Quote Originally Posted by dtpearson View Post
    Unfortunately you will need a unit designed for the Audi CAN-Bus, and while my supplier does have one for the S4, it's 6.5 inch just like OEM:
    Car dvd /Car gps/VW GPS/BMW GPS Professional manufacturer-Audiosources Electronic Technology (Shenzhen) Limited
  9. #869
    Nov 2009
    WA
    Re: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
    Hi,
    I have a 2013 Jetta with bluetooth and OPS. I understand that the OPS will be displayed on the ANS 810 (might need a firmware downgrade) but how would the original bluetooth (not the one from ANS 810) interface with the unit? Is it possible to use the original mic for the bluetooth?
    Thanks
    Sent from my GT-N7000 using Tapatalk 2
  10. #870
    Jun 2011
    Quote Originally Posted by t0n13 View Post
    Hi,
    Thanks
    The unit comes with built in Bluetooth so you will not be able to use your OEM one. The current generation units also do not have an external Mic option, but I believe the new units will - have to confirm on that.
