Originally Posted by
duaned
Mine is still going great with the reverse camera (latest firmware). Shame it's useless during the day because the screen on the head unit can not be seen with a bit of light shining on it. Hopefully the new model has this addressed.
Daylight glare is a problem for most LCD screens, even the latest Smartphones can't avoid it - I'm pretty sure the RNS-510 isn't much better here, if at all.
Do you have the screen brightness set on high? You could also consider an anti-glare screen protector, though they tend to be matte and may reduce screen clarity.
As for RVC that does work fine, the latest firmware seems to only have reversed the sensor for OPS so that people without OPS see the OPS screen and people with OPS don't. If you have RVC but not OPS, this wouldn't really affect you, but if you didn't have RVC either, and it thinks you have OPS, it will switch to the full screen OPS menu where you will be stuck with it when in reverse.
