Page 86 of 149 FirstFirst ... 3676848586878896136 ... LastLast
Results 851 to 860 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #851
    Jun 2011
    Quote Originally Posted by duaned View Post
    Mine is still going great with the reverse camera (latest firmware). Shame it's useless during the day because the screen on the head unit can not be seen with a bit of light shining on it. Hopefully the new model has this addressed.
    Daylight glare is a problem for most LCD screens, even the latest Smartphones can't avoid it - I'm pretty sure the RNS-510 isn't much better here, if at all.
    Do you have the screen brightness set on high? You could also consider an anti-glare screen protector, though they tend to be matte and may reduce screen clarity.
    As for RVC that does work fine, the latest firmware seems to only have reversed the sensor for OPS so that people without OPS see the OPS screen and people with OPS don't. If you have RVC but not OPS, this wouldn't really affect you, but if you didn't have RVC either, and it thinks you have OPS, it will switch to the full screen OPS menu where you will be stuck with it when in reverse.
  2. #852
    Oct 2012
    Newcastle NSW
    Agreed, mine was coming up with the OPS with the RVC connected but there is a little arrow head on the screen that I pressed and it moved the OPS screen (which was on top of the RVC screen) completely away. Win! The Matt screen protector, where do you obtain one that fits the 7 inch screen version?
  3. #853
    Aug 2007
    I bought an Ipad screen protector and cut it to size. Mind you, after sticking it on, I found that it was too dark for viewing so I removed it.
    CW MY12 5Dr manual GTI. ANS-810 head unit.
  4. #854
    Sep 2008
    Melbourne, Australia
    Screen reflection.
    Quote Originally Posted by starionx View Post
    I did the same, perfect. I used a clear finish one.
    Only issue I have is when I wear polaroids
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  5. #855
    Pacific Paradise QLD
    Quote Originally Posted by bazzle View Post
    Bazzle
    Turn the screen protector around 90 degrees and that will fix polarisation.
    Had a ticket machine in a bus like that and if I turned my head to look at it end on it came clear.
  6. #856
    Feb 2013
    Spain
    But then... won't it look bad in an horizontal position?
  7. #857
    Quote Originally Posted by wanxu View Post
    Turn the protector around Not the screen. When they polarize things they work one way and not the other.
    Take your sunnies off and turn them up and down in front of the screen and see if it comes clear Our ticket machines had polarised glass in them and one had been put in crossways instead of up and down or vice versa.
    When I looked at it normally I couldn't see through it If I turned my sunnies 90deg I could.
    Didn't use that bus any more as was a pain
  8. #858
    Jun 2011
    Update on the MCU issue - my mistake, you CAN actually downgrade the MCU, just can't flash the SAME version of MCU that you already have. This means those with the OPS being stuck issue can solve it simply by downgrading your MCU with the last update, until the issue is solved with the next update.
  9. #859
    Dec 2012
    Malaysia
    DkN, any updates on the new version of the HU? thanks in advance!
  10. #860
    Aug 2012
    United States
    Quote Originally Posted by DkN View Post
    When is the next firmware due out? I am so sick of looking at the reversing screen even though i have no backup camera or sensors AND it shuts the audio off.
