-deleted-
-deleted-
Just to make your life easier I would install the original radio. Then plead ignorance.
I had a battery die in my last car after about 18 months and it was replaced under warranty. I may or may not have contributed to its early demise...
Sent from my HTC One X using Tapatalk 2
I agree, but there is a way to mesure the battery drain and if there is a b.drain it would be just a matter of removing the radio fuse to test if the unit is at the fault, which I daubt would be the case, if wired properly.
-deleted-
Ever since I've got the ANS-810, the SatNav has driven me insane. About 50% of the time I start it up, it would take anything up to 10 minutes to get a signal. I've done some testing, and I think I have figured out what the problem is.
Both at home and work, I park my car in an underground car-park. I don't get any gps signal. Over the last 2 weeks, I've waited until I'm just about to exit the car-park to turn the SatNav on. At home, it gets a signal within a minute after it has finished booting (most of the time, straight after booting up). At work, it takes a few minutes, but I attribute that to the tall buildings around.
I'm wondering if there is some logic in the SatNav system that says that if it doesn't get a signal within a certain amount of time after booting up, it goes into some sort of timer routine to check for a signal. This is pure speculation on my part.
All I know is that it works as it should now. Of course, I can no longer use the SatNav auto boot after power up.
CW MY12 5Dr manual GTI. ANS-810 head unit.
Have you tried the reset in this post?
ANS-810 / ANS-510 (PROPER RNS-510 alternative)
Sometimes GPS signal issues might arise after a firmware flash.
One thing I have noticed is that the reversing graphic of the optical parking system has stopped coming up since the last firmware update was applied. The sensors are working as I hear the beeps, just not which sensor has been triggered.
Mine is still going great with the reverse camera (latest firmware). Shame it's useless during the day because the screen on the head unit can not be seen with a bit of light shining on it. Hopefully the new model has this addressed.
