Page 72 of 149 FirstFirst ... 2262707172737482122 ... LastLast
Results 711 to 720 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #711
    Sep 2008
    Melbourne, Australia
    I dont have a remote amp but I used the Blue wire on my previous unit.
    Just put a test light on the wire and trun the ign off (remove key)
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  2. #712
    Jun 2011
    Quote Originally Posted by bazzle View Post
    Bazzle
    That's right, the blue wire marked "ant" is ACC power.
  3. #713
    Dec 2012
    Perth, WA
    Quote Originally Posted by DkN View Post
    I don't remember if I've posted this before but here you go
    <snip>
    Hi DkN,
    I'm not sure if this is possible or already in the works but it would be great if we could have a manual fuel consumption calculator built it. I.e we input how many L's where added rather than relying on what the trip computer thinks its using.
  4. #714
    Quote Originally Posted by daveaus View Post
    Hi DkN,
    Yes..you can get it on your IGO Primo;
  5. #715
    Oct 2012
    South Africa
    When is the obd2 device addon going to be released?
  6. #716
    Jun 2011
    Quote Originally Posted by jeppe777 View Post
    AFAIK the software development has all been completed, only thing left is to order the hardware - they've been extremely busy working on the new platform though so I can't be sure when that is happening.
    Also yes iGo has its own fuel consumption calculator in which you manually enter km travelled and litres of fuel used. I've not seen the OBD fuel consumption module in operation yet so I'm not sure if manual calculation is an option, but remember your fuel consumption monitor can be adjusted via VCDS if you feel it is inaccurate.
  7. #717
    Oct 2012
    Newcastle NSW
    I have had some issues lately (since the current firmware upgrade) where upon starting my vehicle (and the head unit starts) it locks onto the OPS screen. Except I don't have OPS fitted or the supplied reverse camera at this stage. The loom is not even plugged into the head unit. I have to restart the vehicle to restart the head unit to resume normal operation. Any ideas?
  8. #718
    Dec 2012
    Perth, WA
    It would be great if the unit itself had the feature rather than igo. This way you wouldn't need to load iGo or enter the odometer.
  9. #719
    Do you means the OBD features will not be able upgrade to the current generation ANS units.
  10. #720
    Sep 2008
    If you read back thru the threads you will see it is an add on module compatible with later software.
    I dont see it as being that high on the list for this type of product personally. A kufatec is an alternative option that shows in the mfd.
    Bazzle
