Page 71 of 149 FirstFirst ... 2161697071727381121 ... LastLast
Results 701 to 710 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #701
    Jun 2011
    Quote Originally Posted by DkN View Post
    At this stage it is most likely the case that Audiosources will be switching navigation software.
    Is there any way you can give an indication of the nav software being considered? Just trying to decide on this vs other options. thanks!
    Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
  2. #702
    Jul 2010
    Canberra , ACT
    awesome info boys ! thanks very much !!!
    has anyone hooked up a Subwoofer to their headunit yet ?? i can only find ONE subwoofer preout in the wiring loom they provided .. their should be TWO RCA's so you can hook it up to an amp.. perhaps mislabeled ?
    also with the Remote wire for the amp .. is it one of the lose yellow or black wires off the main loom at the back of the head unit ?
    thanks
    sam
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
  3. #703
    Mar 2012
    Quote Originally Posted by Golf-Sam View Post
    thanks
    sam
    Just one sub out from head unit.
    i seem to remember having to use a voltmeter to work out switched 12v.
    might even have T'd off from Antenna power feed?
    sorry it was 6 mths ago.
    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
  4. #704
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by whiskywallah View Post
    thanks for that info mate
    figured it out after going through a fuse lol
    the Yellow wire coming out from the main harness (B+) is meant to run the Remote on an aftermarket Amp ..
    as for the Subwoofer .. i used the Sub out for the Positive RCA and Hooked up the Negative to the Negative of the Rear speakers .. seems to be running just fine .. and got it all tuned and running properly ..
    sam
  5. #705
    Aug 2012
    United States
    thanks
    sam
    There is a subwoofer y adapter to split from the one RCA to two. .Works perfectly and now you have separate sub control on the units. Good stuff.. check eBay!
  6. #706
    Jun 2011
    Quote Originally Posted by boltor View Post
    It seems the final decision is that we will stick with iGo. We considered Sygic but eventually decided iGo was the better (though more expensive) option.
  7. #707
    Jun 2011
    thanks for the update, most appreciated. iGo seems to have a good user base and be well supported, so probably makes sense. Will be interested to see boot time and performance of iGo on the new hardware.
    also, can't wait to see any teaser info on the OBDII capabilities (just like the displays on a Nissan GTR? )
  8. #708
    Jun 2011
    I don't remember if I've posted this before but here you go
  9. #709
    Jun 2011
    brilliant! thanks for posting!
    I guess they have looked at the idea of actual dials for some parameters - boost, etc? I assume that the new unit would have enough processing power for this?
  10. #710
    Jul 2010
    Canberra , ACT
    I Take it back ! the remote is not set right .. the Amp is still getting power when the car is off .. i hooked up my remote to the YELLOW wire coming out of the head unit .. and it's not turning the amp off when the HU is off .. any ideas ? how are you guys doing it ??
    Sam
