Page 70 of 149 FirstFirst ... 2060686970717280120 ... LastLast
Results 691 to 700 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #691
    Dec 2012
    Michgan, USA
    Quote Originally Posted by Golf-Sam View Post
    when it's toggled on , i approach a turn .. front speakers lose sound and nothing comes from the nav ..
    so i have it toggled off for now because its annoying .. would it be that the nav is missing sound files ?
    sam
    Could be. The igo software does have 'voice' files. You may have more than one choice already in your Navi Settings. If so, try changing voices and see if that makes a difference. I know mine comes with a male and female voice option. I have the igo8 software straight from audiosource.
    Paul.
  2. #692
    Dec 2012
    Michgan, USA
    OK. I ran the ipod interface and still had some issues but was finally able to have it generate proper lists of songs, artists, albums, etc. And, I was able to see the song and album names on the 'play' screen. I turned off the Navi when I ran the ipod interface and it started working then. Not sure if it was a coincidence or somehow this is related.
    I did notice a small bug. On the time counter on the music display it is missing the leading zero for the first 10 seconds of each minute (ie, instead of 1:01, 1:02, 1:03, etc it shows 1:1, 1:2, 1:3....). Once it gets to seconds 10-59 it displays properly.
    Paul
  3. #693
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by schultp View Post
    Paul.
    cant find the setting for the Male , female voice ..
    where do you change that from ?
    sam
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
  4. #694
    Jun 2011
    Sydney NSW
    Just discovered, there are card readers, and then there are card readers.
    My laptop has a built in SD card reader, however it will NOT read the mapping microSD card. It turns out that not all card readers will read microSDHC cards. Looks like I am going to have to get a USB card reader so that I can update my maps.
    I have a 2 GB microSD card, and I can put it in an adaptor and it is read /formatted without issue. I first bought a 4 GB microSDHC card, and it is not even recognised as a "disk". I then discovered that not all card readers will read/recognise a microSDHC card.
  5. #695
    Dec 2012
    Michgan, USA
    Here's some excerpts from the igo Primo pdf manual I downloaded from navitotal.com
    Adjusting the Navigation Voice Volume
    While the Navigation is on and a route has been programmed, the Navigation will
    speak commands. While the Navigation is speaking, adjust the volume by turning
    the radio volume knob. The Navigation volume will remain at this level and when
    done speaking will return to the previous source (ie, radio) at the volume level set
    for that source.
    The main volume must be set above zero in order to hear the spoken directions. If
    the radio is muted, the Bluetooth engaged in a call, or the volume knob has been
    turned to zero, the navigation will not be heard but your visual directions will
    continue.
    I am not out at my car but from memory there is a settings section under the menu screen. Somewhere in the settings area I found the choice for two different voices. I am now just recalling that there may have been a setting for navigation volume too. Tomorrow I'll investigate when I am out in the car.
    ...it is late at night on this side of the globe
    Paul.
  6. #696
    Dec 2012
    Michgan, USA
    Quote Originally Posted by wai View Post
    Thanks for the heads up on this good info. I have some microSDHC 4gb cards coming in the mail. I have never used my card reader on my computer. Hopefully, it will recognize the microSDHC format.
    Paul
  7. #697
    Sep 2008
    Melbourne, Australia
    In my Primo you go to sounds and warnings TTs voices and select.
    DepositFiles
    Download may be slow but its a P2 with Oz 19.3 maps etc I optimized for myself.
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  8. #698
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by bazzle View Post
    DepositFiles
    Bazzle
    thanks for that Bazzle .. champ !
    sam
  9. #699
    sam
    Try to download OTOVEN1_iGO_NAV from this link and read about it: OTOVEN1_iGO_NAV.pdf - Download free. Direct Link - General Files
  10. #700
    Paul.
    The Navi Volume setting was under Setting Menu as the pic below:-
