I'll try mate but if you ended up flashing the wrong firmware on it, I'm not sure if it's possible to fix it. Check your PM.
Interesting adapter - that looks like it would work. Although, what is the idea behind using it? The audio might work but music ID3 tag display wouldn't. If the USB is just there for charging, then the same thing can be achieved by using the normal USB cable provided with the unit, and then using a normal 3.5mm from the Aux-In slot, or just BT stream.
