Originally Posted by
starionx
Finally got round to updating the FW. It seems the USB side is now broken. If USB is the current input and you reboot the unit, it hangs on the Welcome screen. Pressing the menu button does nothing. I found that pressing the Equil button (ASP) brings up that screen. From there, I can press the Menu button which takes me to the USB screen, but doesn't play or recognise the drive. Interestingly, if I unplug the drive it gives a NO usb drive present message (or something like that). It plays the SD card fine and the radio.
Checking the fw version, it shows 20120405. I didn't check what it was prior to updating. The version I downloaded was the '405 one.
I reinstalled the fw, but it does the same thing.
Thoughts?
That's a bit difficult to say, if it was working before then it seems like it's the firmware. I am not certain what would happen if you flashed the wrong firmware for your hardware, but I was told it is very important to get it right. Having said that I'm fairly certain you should have the 20120405 BT. which firmware version did you flash? The one from my last email?
kajkac
In what resolution i must rip videos to get the video working beacouse 800x480 is not working only pink picture i get.
What format are you ripping the video to?
