Originally Posted by
Dazedconfused
Interesting thread. Seems like a great product still in it's infancy. Lots of little bugs and things, but a group which seems keen to improve the product asap. DkN, I love your input with your customers, helping them with everything along the way, replying to every post. Awesome.
I'm in the market for a new LCD type unit for my 2008 MK5 GT Sport, and was going to go OEM, but since seeing this...I'm not sure which way to go now. For me, not being tech minded, the price was right, but it seems a bit user intensive; setting it up and maintaining it etc? I wouldn't have a clue how to install all of this stuff.
Out of curiosity, what is the CAN-Bus?
Essentially all I'm after is an LCD panel display for my radio (SATNAV would be a bonus) for my car over the tragic little OEM unit. and seat warmer or A/C functionality is separate to the unit as well. I guess watching DVD's and having the SD/USB functionality would be a bonus as well, but unless I'm on a trip I just listen to the radio.
Thanks for the compliments
CAN-Bus is the central gateway through which all your car electronics communicate with each other. For head units, the relevant information accessible from the CAN-Bus include things like steering wheel controls, MFD display, AC info (but for cars with white MFD only), door open status, and also diagnostic information.
The reason your generic aftermarket Alpine etc units will not retain steering controls is precisely because of the CAN-Bus. It's not a simple button wired directly through to the head unit as is the case for older cars, it goes to a steering control unit which then sends the info to the CAN-Bus, and the head unit must read this information from the CAN-Bus to know which button was pressed.
If you use radio more than your own portable music then the one caveat here is that some users seem to have some signal issues, mostly with AM but a couple with FM interference too. If you can afford waiting, a DAB+ solution is coming, but probably still a few months away. They've had an issue with the original supplier of the DAB+ chip and only just found a new one to start over with. That's not to say you will have FM issues if you purchased now, just that the chance seems to be there.
Also, the unit is plug and play and no more difficult to install than the OEM unit. In fact the OEM units need to be coded to the car, and then also coded for functions like OPS and reverse camera, so in that sense this unit is easier to install. Any installer capable of installing VW units can install the ANS. In fact any audio installer will be able to install the ANS, the concern is more about if the installer would know how to properly remove your trim without damaging it.
