Thank you for the firmware update - Have solved some of the SW errors
The ANS810B works fine with Skoda logo and green lighting in the display.
ANS 810B will not change to green "keys"!
I have followed the instructions from this thread without success - what can I have done wrong?
Picture of the model I have[URL="http://www.audiosources.net/productshow.asp?bid=28&tid=62&sid=62&id=65"]
I still think that there are some buck with the FM radio when the RDS is turned on.
Examples of strange behavior - when RDS is turned on.
- FM1 no.1 frequency is 87.50 MHz without RDS - I turn on RDS now is the frequency 113.50 MHz no signal. the same for the no.2. Remaining 3 to 6 are ok.
- Some time when RDS is on and I press no2. and it switch No. 2 and it is also that channel that it switch to fur after a few sec. the display indicate that it is playing on no. one. but i playing on no. 2. the same will happen if i press on no.5. if I turn of RDS no problem.
- Frequently change between different transmitters - completely unnecessary since the signal is ok. Typically it will change for every 2 to 5 minutes.
I have this on video - maybe Audiosources would be interested in these video?
And some time it get frozen on OPS, when i start ny car, and nothing works - I have to turn of the engine to make it work again!
I don't have OPS in my car yet - hop to have it one day.
