Is there any way I could fine tune the radio, I kept getting this crackling sound every 2-3 seconds. Getting kind of annoying..
Sent from my GT-I9300 using Tapatalk 2
It is not fixed in the new firmware but I am pushing - there are a few technical programming niggles to sort out. In the mean time if this is a big issue for you it may be an alternative for you to use BT stream on your phone.
I'm happy to help if you have any issues with your unit but if you just want to keep up to date with latest firmware and news + support, I provide this for a one off subscription fee of $25 AUD.
The procedure should be identical to when you first set up the unit - can you describe in a bit more detail? If you choose select GPS file path, you should see a folder "Primo2", choose that folder, then swipe up (this is laggy I know) to scroll down the list until you see Primo.exe.
If I may also add, the antenna adaptors with dwo separate leads will not be able to be used with the plug that has double connectors on the car's wiring harness. Basically, when you place the two separate plugs side by side, their spacing is too great, and only one plug can have a locking peg.
If your wiring harness has two sockets in a single unit, you will need something like the this one
Audi VW Volkswagen Radio Dual Fakra Diversity Antenna Adapter [CT27AA56] - $19.95 : SimpleSoft,, Simple Solutions That Work!
If you pick on the image you will get a full screen one and you can see how close they need to get and only one has a locking peg.
The most frustrating thing (apart from the reception) is waiting for it to get here. I ordered mine on Oct 1, and it is supposed to have left the LA facility on Oct 3. I suppose they have to build and certify the aircraft :-^) and then there is Australia Post.
Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
Thanks guys, placed an order for the adapter. Got the same one as whiskywallah. Hopefully this is fix the issue.
Hi DKN,
Is there any updated firmware for unit BT20120512?
BT20120512 is interchangeable with 20120405.
Also in response to someone's query about seat warmer display not showing a couple of pages back (posts here moving pretty fast these days), my technician says that they've confirmed seat warmer display to work on a Passat CC. The display probably just looks a bit different to the stock RNS-510 one? I cannot confirm myself since there is no A/C display for a mk5 Golf.
Ay news yet on the obd function??
