Page 39 of 149 FirstFirst ... 2937383940414989139 ... LastLast
Results 381 to 390 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #381
    Hey Sandy,
    Hows the it going with the iPod side of things? In particular selecting tracks.
    Currently the only way is alphabetically and my unit won't go past the 'C's', pretty much makes it useless.
    It would be great if we could select Albums or artists, anything other than alphabetically!
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
  2. #382
    Jun 2011
    Quote Originally Posted by spraycanmansam View Post
    Hey Sandy,
    Did you not receive my firmware update email? Browse by artist etc has been implemented but it's still beta with quite a few bugs, you can see how it is working in the new firmware update.
  3. #383
    Hey Sandy,
    Sorry mate, just trawled through my email and it got sent to my junk folder, all fixed now.
    I updated the firmware and it's definitely better! Can't wait till it's polished
    Polo GTI MY2008
    Build Thread
  4. #384
    Aug 2012
    United States
    any updates on the OBD2 functionality?
  5. #385
    Jun 2011
    Quote Originally Posted by DSGVW View Post
    Swipe up from the main menu after the latest firmware flash, you will see a full preview of the OBD2 interface. I'll keep everyone posted on availability.
  6. #386
    Jun 2011
    Sydney NSW
    On the station changing, I did some tests and found that when it started to station hunt, the AF on the radio screen would start flashing. Also, when I eventually managed to get it to the station I wanted, every so often, the sound would go off and then a second or so later would come back on. This would happen every minute or so.
    When I got home I searched for the meaning of this and it turned out that it is related to the RDS function and AF was for Alternate Frequency. Basically if the unit believes the signal was not strong enough, it would try and find an alternate frequency, and while doing this would mute the sound.
    I have turned off the RDS function and this turns off the AF function. I'm not too fussed with losing the FM station name.
    On future firmware upgrades, any chance of providing scroll buttons on the screen rather than having to waste time trying to swipe to scroll
  7. #387
    Aug 2007
    Still on the old FW, but I believe any audio updates were IPOD related.
    The Random track (could be also Repeat... didn't check) function (usb/sd) does not 'stick' when the unit restarts. It always goes back to normal play. This, to me, is almost a deal breaker. If it's fixed with the new FW, I'll update asap. If not, I'm going to put my RCD-510 back in until it is.
    CW MY12 5Dr manual GTI. ANS-810 head unit.
  8. #388
    Mar 2012
    Quote Originally Posted by starionx View Post
    There's a few 'little' things like that which make the difference between a run of the mill audio player and one that is a pleasure to use and recommend. For me it's the browse timeout (only 5 secs) and the fact that on start up it will always go back to playing track 1 from the iPod instead of what you were last playing amongst other things. I'd be interested in other people's feedback.
    I believe DkN when he says he is pushing hard to get updates so I'm prepared to stay with it a bit longer
    BTW KAJKAC, you need to talk to DkN directly to find out why you're not on the mailing list for FW updates.
    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
  9. #389
    Jun 2012
    Canberra
    So I just installed the update.....and it did change everything back to Chinese! Can't see any other differences as yet. However, when I select Navigation - it says to create path.
    I go into settings, general and can see the primo sitting there. I have tried pushing the "Tick button" on every screen inside those folders but nothing works.....
    Any help???
    Thanks!
  10. #390
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Big Jase View Post
    So I just installed the update.....when I select Navigation - it says to create path.
    This is the part where you have go to the folder and scroll by swiping up to get to it. It is a pain because the unit thinks you have selected rather than scrolled and takes you elsewhere. You have to keep at it and fortunately it only has to be done once after the upgrade.
    This is where the firmware should provide a scroll up and scroll down button like the return button. It would make things so much easier.
