Hey Sandy,
Hows the it going with the iPod side of things? In particular selecting tracks.
Currently the only way is alphabetically and my unit won't go past the 'C's', pretty much makes it useless.
It would be great if we could select Albums or artists, anything other than alphabetically!
Hey Sandy,
Sorry mate, just trawled through my email and it got sent to my junk folder, all fixed now.
I updated the firmware and it's definitely better! Can't wait till it's polished![]()
any updates on the OBD2 functionality?
On the station changing, I did some tests and found that when it started to station hunt, the AF on the radio screen would start flashing. Also, when I eventually managed to get it to the station I wanted, every so often, the sound would go off and then a second or so later would come back on. This would happen every minute or so.
When I got home I searched for the meaning of this and it turned out that it is related to the RDS function and AF was for Alternate Frequency. Basically if the unit believes the signal was not strong enough, it would try and find an alternate frequency, and while doing this would mute the sound.
I have turned off the RDS function and this turns off the AF function. I'm not too fussed with losing the FM station name.
On future firmware upgrades, any chance of providing scroll buttons on the screen rather than having to waste time trying to swipe to scroll![]()
Still on the old FW, but I believe any audio updates were IPOD related.
The Random track (could be also Repeat... didn't check) function (usb/sd) does not 'stick' when the unit restarts. It always goes back to normal play. This, to me, is almost a deal breaker. If it's fixed with the new FW, I'll update asap. If not, I'm going to put my RCD-510 back in until it is.![]()
CW MY12 5Dr manual GTI. ANS-810 head unit.
There's a few 'little' things like that which make the difference between a run of the mill audio player and one that is a pleasure to use and recommend. For me it's the browse timeout (only 5 secs) and the fact that on start up it will always go back to playing track 1 from the iPod instead of what you were last playing amongst other things. I'd be interested in other people's feedback.
I believe DkN when he says he is pushing hard to get updates so I'm prepared to stay with it a bit longer
BTW KAJKAC, you need to talk to DkN directly to find out why you're not on the mailing list for FW updates.
Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
So I just installed the update.....and it did change everything back to Chinese! Can't see any other differences as yet. However, when I select Navigation - it says to create path.
I go into settings, general and can see the primo sitting there. I have tried pushing the "Tick button" on every screen inside those folders but nothing works.....
Any help???
Thanks!
This is the part where you have go to the folder and scroll by swiping up to get to it. It is a pain because the unit thinks you have selected rather than scrolled and takes you elsewhere. You have to keep at it and fortunately it only has to be done once after the upgrade.
This is where the firmware should provide a scroll up and scroll down button like the return button. It would make things so much easier.
