Originally Posted by
Jans
Hi DKN,
Yes I have checked the cables twice. As I mentioned the CAN works. ie All the steering wheel controls work. the Door indication works, the optical parking system works as well as the climate control etc.
The connector as shown on you picture has two parts. The A part which is the speaker connection (to the amplifier) and the CAN bus connection which is part D.
As for updating the them I go to system - change vehicle and select the Skoda. Then switch it off and on.
As for keeping up to date. Woudl love to but first want to get the thing working.
Look forward to your advice.
The fact that you don't get sound out of any speaker makes it sound like something internal to the ANS unit is faulty. Can you connect to any of the RCA audio outs, and see if you get any sound?
Also to change the theme properly you need to do a full firmware flash, because the boot screen can only be modified then. To just change the colour, first go to settings -> display and change colour to green. Then, go to Aux-in, touch and hold the middle of the far left of the screen, choose model select, and change colour theme to green then restart the unit. This changes everything including the loading screens, but does not change the boot screen. I will send you the firmware with Skoda boot screen, flash it first and then change theme to green. Unfortunately I don't think new firmware will help with the audio issue if there is faulty hardware - if you don't get audio from the RCA out either you would most likely have to send it back to China.
