Page 36 of 149 FirstFirst ... 2634353637384686136 ... LastLast
Results 351 to 360 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #351
    Jun 2011
    Quote Originally Posted by Jans View Post
    Hi DKN,
    Yes I have checked the cables twice. As I mentioned the CAN works. ie All the steering wheel controls work. the Door indication works, the optical parking system works as well as the climate control etc.
    The connector as shown on you picture has two parts. The A part which is the speaker connection (to the amplifier) and the CAN bus connection which is part D.
    As for updating the them I go to system - change vehicle and select the Skoda. Then switch it off and on.
    As for keeping up to date. Woudl love to but first want to get the thing working.
    Look forward to your advice.
    The fact that you don't get sound out of any speaker makes it sound like something internal to the ANS unit is faulty. Can you connect to any of the RCA audio outs, and see if you get any sound?
    Also to change the theme properly you need to do a full firmware flash, because the boot screen can only be modified then. To just change the colour, first go to settings -> display and change colour to green. Then, go to Aux-in, touch and hold the middle of the far left of the screen, choose model select, and change colour theme to green then restart the unit. This changes everything including the loading screens, but does not change the boot screen. I will send you the firmware with Skoda boot screen, flash it first and then change theme to green. Unfortunately I don't think new firmware will help with the audio issue if there is faulty hardware - if you don't get audio from the RCA out either you would most likely have to send it back to China.
  2. #352
    Apr 2011
    Cool
    Finally got ANS610 installed in Golf MKV over the grand final weekend.
    Thanks again DKN for all the help over PM.
    The installation is pretty straight forward (have not install the RVC), got sent the wrong version of RVC instead. I did test the ANS610 with another camera, the unit switch to camera input once the camera is detected. I thought it was detecting signal via canbus, but as DKN suggested, I need to have relay inplace to get that sorted. I will try it again once I got the RVC from DKN.
    The head unit itself isn't flushed in to the dash like OEM. Its out by 1-2mm. No biggy. The knobs feels abit loose and specifically the Menu button is abit loose and it has this clicking sound, the other buttons are fine. Not sure if it suppose to be that way. Hopefully it wont cause any issues.
    FM Radio is ok. Minor interference now and then when driving around Melb CBD. Abit annoying at times with the subtle crackling sound. One thing I notice is that, if I'm in the Navi mode, I press the Radio button, it changes to switches the FM/AM(still in Navi mode) instead of navigating back to Radio mode. Same when I try to navigate from Phone mode to Radio. I have to go back to the menu, then select Radio. Not sure it is a bug or was meant to be that way.
    I had the same issue with wai, if the radio lost signal or just started the car up, it was on some other station and band and the preset station highlighted isnt always the one thats playing.
    BT, is pretty straight forward. Very very basic function, it would be great if there is a search or even filter the phonebook when you dial from the screen. Scrolling through 100s of entries kind of a pain. I guess I could just dial from the phone itself. Steering wheel phone button is a known issue, thats ok.
    I got no ipod, so I have not tested that yet. DVD works fine. Mp3 files from SD card works fine as well, would be great once the id3 tag is fixed.
    USB, does not support NTFS. Im sure it supports FAT32 since the microSD works. Will try other format when I get the chance.
    Overall, I'm quite happy with the unit. You get what you paid for. Definitely 8/10. Would be really great if they could fixed all the bugs before implementing new features.
    Looking forward to the new firmware.
    Thanks again to DKN.
  3. #353
    Mar 2012
    Quote Originally Posted by turbo81 View Post
    +1 from me on that score....
    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
  4. #354
    i think i need to get a camshak or other 1.6canbus to 2.0 so i can get the back up directional lines and air con stuff on the screen . i feel like im missing out
  5. #355
    whats with the google thing in the gps part btw/>?
  6. #356
    May 2010
    Quote Originally Posted by DkN View Post
    Does the air con status display when you adjust the climatronics unit? I will ask about the seat warmer if the climatronics information shows up but seat warmer info is missing, it shouldn't be too difficult.
    I will organise new firmware tonight.
    The climatronics unit displays fine its just missing the seat warmer icons, hopefully they can fix it cheers.
  7. #357
    Jun 2011
    Quote Originally Posted by chocolatemoose View Post
    It does sound like there are some CAN-Bus issues here, as I said for all other cars the ANS is compatible with CAN-Bus 1.6 but it looks like there's some issues with the Touareg.
    Regarding the air con info, that is not even existent in the CAN-Bus gateway unless you have the new white MFD, so if you just use a 1.6->2.0 adapter you probably still won't get that - you should get everything else working correctly though.
    iGo Primo has internet capabilities, you can use Google search for address and internet servers for traffic but the current ANS system does not support 3G function.
  8. #358
    Jun 2011
    Sydney NSW
    I don't know what happened, but this ended up in the wrong thread, so I am posting it back here.
    I went out today (I have been laid up) and this time was ready for the change of radio station.
    Everything was OK when I drove into the underground parking station. There was barely a radio signal, but it was holding onto the station.
    I shut the car down and set the alarm as I went for my appointment. When I got back, I turned everything on and started the car. Now, it could not get a satisfactory signal for the radio and so switched to preset position 1. Me being me I have my preset stations in increasing frequency as it makes it easier to search for them and the radio station I was on was the first button on the lower row. As a result, the radio decided to switch the preset to 1, and naturally got nothing as this is a frequency normally used in regional NSW and not in Sydney. I had to wait until the satellite search was completed for the navigation system before it would let me switch to the radio screen and change it to the desired preset.
    So, to avoid this happening in future, is there any way that the radio can be set to NOT try and find a radio signal that is stronger or default back to preset 1?
    Thanks.
  9. #359
    Jun 2011
    I will ask to either have a user option or have this feature turned off. China is currently on holiday though, October 1st is the national day and they get about 10 (yes a whole 10!) days worth of public holidays for it.
    In other news, I've just sent out the latest firmware updates.
  10. #360
    Aug 2007
    Sandy, is there any way of going back to the previous FW version in case there is a major issue with the new one (just in case)?
    CW MY12 5Dr manual GTI. ANS-810 head unit.
