Originally Posted by
chocolatemoose
just receieved my ans710 today for my touareg. looking forward to getting this unit in. did any of you find a spot for the DTV arials ?
i dont understand how AM reception be bad. or any reception. these are modern cars. and if a crappy old 80s hand held can get crystal clear reception. why cant these VW?
im thinking of taking my reverse camera and the head unit down to a VW mob and getting them to install it all.
moose
The single antenna connector is for analog TV (standard antenna connector), which the units come with. I don't even mention it because it's pretty pointless, analog signal is terrible and will be phased out soon enough. If you purchased the DVB-T module you will have dual screw-on antenna connectors coming out of the two holes. I don't bother with DTV in the car myself, but people who have installed them usually suggest behind the rear view mirror. The cable would probably go through the glove box, up onto the dash somehow, then routed around the windscreen till it gets to the rear view mirror. Or maybe if you just let the antenna sit against your A-pillar.
With the install, I think you will be ok with the Touareg. It always varies from car to car, but I found with my Golf that there is plenty of room under the stereo, behind the climatronics unit, so the CAN-Bus cable can just be tucked downwards into empty space. The reverse camera though is what will take up the bulk of your time and effort and if you're not comfortable removing trim & feeding wires around your car you should probably get someone else to do it.
