Page 32 of 149 FirstFirst ... 2230313233344282132 ... LastLast
Results 311 to 320 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #311
    May 2012
    Installed the headunit, I'm getting really bad static at the moment, any ideas on what I can check? When I press the Dimmer button, static is louder on the low setting than the high setting. If I press the Dimmer button so the screen shuts off, the static goes away.
  2. #312
    Jun 2011
    Quote Originally Posted by prince View Post
    You mean static like cracking noises in the audio? Does it happen on both radio and SD / USB?
  3. #313
    May 2012
    It's more like hissing/interference.
    It's really bad with Bluetooth, very minor with radio and it's not there with SD.
  4. #314
    May 2012
    Here's two videos, turn the volume up as my phone microphone isn't that great:
    Headlight/ANS-420 Screen Dimmer Interference:
    Bluetooth/Phone Interference:
  5. #315
    Jul 2012
    Quote Originally Posted by DkN View Post
    I've never owned an iPhone and never will
    same....
  6. #316
    Jun 2011
    Sydney NSW
    Ok, I have just installed mine and here's the report.
    As I mentioned in my PM to DkN, there were a couple of surprises when I opened mine. The plug positions for the AUX video/audio in/out were swapped with the ones for the iPod/USB. Sorted that out, but in the end, I have not fitted them as I could not get a path for the iPod/USB cables out, and there would have been little if any room for the video/audio plugs. This will need some fiddling if I get a reversing camera. No problem.
    I started this around 8:30 am (in the relative cool of the morning), and the first hurdle was to remove the trim. I purchased the trim removal kit, and it was still not easy until the first "bang" as the lower left clip released. One of the videos suggested to start on the side clips first. Not a good idea as it would have damaged the dashboard. As it was I used a business card (mine) to reduce the force on the dashboard. Once I realised how hard to prise, the remaining 6 clips were relatively easy. Never get overconfident as that is the simplest way to break the trim. I released the 4 screws (a toolkit I purchased over 12 years ago had Torx bits so that was good). I unplugged the CANBUS plug after lifting the lever, and released the antenna plug. The old unit came out relatively easily.
    Next I positioned the GPS antenna. By the way, the unit supplied is not magnetic as the sheet indicated. No problem as I found a surface out of the way and stuck it there.
    I then connected the CANBUS plugs to the back of the unit and connected the antenna and connected it to the power lead. I then connected the vehicle CANBUS plug to the socket that comes with the unit, remembering to use the lever to lock the two together.
    Now the very awkward bit. There is precious little room at the back and trying to find a place to hold the huge lump of the CANBUS plug and socket was a major problem. I ended up having to stuff things in there to get everything to fit.
    It does not help me, but the manufacturer should seriously consider using a proper CANBUS socket as this would eliminate the space issue. After quite a while I managed to get all the bits located so that the four mounting tabs were properly seated and I did up the screws. Oh, yes, I hooked up the GPS antenna lead before securing things.
    Now the really frustrating bit. The touch screen was almost impossible to use. Trying to find Primo.exe was a nightmare. I did get it set but it was like winning the lottery!
    It was now 10:30 am
    I then got the basic bit working and headed off to get my newspapers. I use the navigation screen and found it worked perfectly. There was no lag. I did find the speed warning a little annoying as going just 1 km/h over set it off. I have adjusted this up a touch.
    When I got back I transferred all my favourites over from my Garmin GPS unit. I say transferred but it was a case of entering them in one at a time. The menus are a little confusing, but I managed to get the approximately 20 favourites transferred over. Now I did see an option to rename a favourite, but when I needed to, I could not find it again. I deleted the two offending entries and added them again.
    After I finished this, I went to change some other settings, and noticed that the touch screen responded much better than initially. Maybe it had become seasoned or enough of my finger grease had coated the screen to make it work better. The Primo screens responded heaps better than the main unit screens did. Maybe the settings need to be adjusted a bit.
    I put the trim pieces back and applied some vaseline to the socket parts to hopefully let them release a little easier. The trim went back perfectly, except for the bottom of the unit. It protrudes 1 mm or so at the bottom. It is even. Not really an issue.
    Sadly, AM reception is non-existent. This is a bit of a disappointment. I really can't see why this should be the case. When I set it to AM or off a station, there is quite a background hum. It cannot be an ignition issue as I have a diesel. What I would like to see is an adaptor that makes use of both of the antenna circuits that are provided with the VW Caddy Maxi Life.
    Bluetooth pairs with my iPhone without any issues. I am yet to receive a call though. Interestingly, even though I was supposed to get an ANS-610, the Bluetooth bit on my iPhone says it has found an ANS-510.
    All in all, generally positive, but with a couple of negatives.
    The worst part was trying to find a space to stuff the cables into. My fingers are still tingling and it is now 1:15 pm.
    One more thing.
    When I put the car in reverse, the image comes up in the display, but when the sensor picks up something and beeps, it does not show which sensor has triggered or how far back from the vehicle it is. A minor issue is that it does not show MY vehicle!
  7. #317
    Aug 2007
    Quote Originally Posted by wai View Post
    ...Now the really frustrating bit. The touch screen was almost impossible to use. Trying to find Primo.exe was a nightmare. I did get it set but it was like winning the lottery!
    I'm glad it wasn't just me that thought the same thing.
    ...After I finished this, I went to change some other settings, and noticed that the touch screen responded much better than initially. Maybe it had become seasoned or enough of my finger grease had coated the screen to make it work better. The Primo screens responded heaps better than the main unit screens did. Maybe the settings need to be adjusted a bit.
    Exactly. The touch commands in the Primo screens work as I would expect. The main setup screen... not so much.
    CW MY12 5Dr manual GTI. ANS-810 head unit.
  8. #318
    Jun 2011
    I will investigate the buzzing issue, just have to go through some hassle to get those videos to the tech since China doesn't have access to Youtube.
    Re the touch screen, as I mentioned it is resistive and it's not the most ideal to swipe with, but tapping buttons shouldn't be any issue. The GPS setup screen is very slow and unresponsive I know, but other than initial setup and after some firmware updates it is never used.
    Re the CANBUS cable, they don't make the connections at the back proper CANBUS because not all vehicles have them, especially in China, some of the mk5 Golf and equivalent generation VWs actually don't come with CANBUS. So using the CANBUS adapter maintains the most flexible compatibility.
    Interesting mention about the AM reception, I get non-existent AM as well and I have a diesel. It's one of those mysteries, most others seem to get good AM reception...
    Re the reverse sensors, do you have the OPS module and properly coded? What was your head unit before, did it display reverse sensor info?
  9. #319
    just receieved my ans710 today for my touareg. looking forward to getting this unit in. did any of you find a spot for the DTV arials ?
    i dont understand how AM reception be bad. or any reception. these are modern cars. and if a crappy old 80s hand held can get crystal clear reception. why cant these VW?
    im thinking of taking my reverse camera and the head unit down to a VW mob and getting them to install it all.
    moose
  10. #320
    Jun 2011
    Sydney NSW
    I have a Caddy Maxi Life which comes with the senssors as standard, so there should be no issue. The original unit was a RCD-310 and the sensor information was correctly displayed. There is no specific vehicle for the ANS-610 when you go to choose a vehicle. I had the default one selected and maybe that is what caused it. Quite by accident I held my finger a little longer when selecting the vehicle, and suddenly things shifted a little and there was one for the Tiguan. I selected the Tiguan and then got a box and put it behind the Caddy and selected reverse and the indications showed up. Maybe the default vehicle does not come with it as standard.
    So, the OPS display appears to be working. I will get to test it again tomorrow.
    On the AM reception, it has to do with the antenna that VW provide (which is hopeless). Maybe, just like the GPS antenna, just supply an aftermarket stick on antenna. You can find them with a search. The problem is getting the cabling/connectors right. The AM/FM specific antenna is a bit of an overkill. After all, my Hiace had an AM/FM radio that was brilliant and it had a straight stainless steel A pillar antenna. This business of it having to be specific is a little rich.
    On the CANBUS plug, maybe the best solution would be to have the cable provided say another 150 mm longer. This would allow you to tuck the CANBUS plug out of the way, and then there should be no issue. because even with any excess cable curled up there would be no real problem. I'll be the puineagig
    Now while I have you, is there a way to edit the name you have entered for a GPS favourite? Also, can the phonebook be edited? I got it to download the phonebook from my iPhone, but found it only took the first number where an entry had multiple numbers. I am not too fussed about it as the Bluetooth phone business is to receive calls rather than make them. To make a call, I can ask Siri to do that if necessary
