Originally Posted by
wai
Ok, maybe a little clarification on this is needed.
On my MY11 Caddy Maxi Life, the RCD-310 has both Optical Parking System (OPS) and Park Distance Warning System.
The RCD-310 has a monochrome display and when reverse is selected, the volume is reduced and the RCD-310 display shows a plan representation of the Caddy and then each of the 4 sensors which trigger do so with the display showing in which zone the particular sensor is triggering.
At the same time, the Parking Distance Warning System indicates which zone has been triggered with a beep, and the beeping becoming more rapid as the zone gets closer to the back of the vehicle. The Parking Distance Warning System can be muted on the steering wheel.
Mine was factory fitted, so I take it that this should be ok with the ANS-610?
Yes yours would be fine, retrofits would be fine too if properly coded, provided it was OPS which is an additional module, not just the PDC (Park Distance Control). I was referring to the Italian user who was having issues with his. The ANS is able to show the OPS info graphically with separate sensor zones, I think the second video in the first post shows this.
