Originally Posted by
chocolatemoose
i have another Chinese after market head unit in atm. it was in when i bought the touareg so im not sure what model it is. and now my maps have frozen. i cant seem to get a gps fix. the little icon has me stuck turning out of the street near work. anyone know if there is a generic reset for these units running igo8 mapping?
any idea when the new ans710 should arrive?
If it has a GPS SD, grab it out and delete / rename the folder in it called "save". It could be in the root directory or maybe they put the map software in a folder e.g. "igo8", but it sits in the root directory of the GPS software. Getting rid of the save folder will reset all the settings in iGo8.
I posted in the group buy thread but I guess not many people are taking notice of it anymore, there is a delay with the unit for about 2-3 days so at this stage delivery looks to be around the 21st, with a chance of it being Monday 24th depending on how fast they get to me and how far you are from Brisbane.
VWPASSAT3C
Hello all, sorry for my poor English. I'm from Italy, I read this thred last two months and I have decided and I bought the version ANS810 for my Passat 2008. I installed it, but I found two problems:
1. When I set the language in the menu in Italian the entire menu remains in English, if I try with other languages, everything changes for example German or French. If anyone can check also kept on his radio if you set the Italian language, or this is just my problem. I would be very grateful.
2. I can not see the screen with Parking sensors, when they are activated. Maybe i need to change the model of CAN in the menu and the model of the car, but which to choose? Quest last question and more for DKN.thanks
I will take a look at the Italian menu.
With the parking sensors, did you install them yourself? Are they just PDC (sensors by themselves) or OPS (which has a separate module that allows optical display)?
The CAN-Bus select doesn't do anything, they use specific CAN-Bus hardware for specific car models for better integration, there is no longer a fit-all decoder. Therefore you can ignore that setting.
