Page 29 of 149 FirstFirst ... 1927282930313979129 ... LastLast
Results 281 to 290 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #281
    Jun 2011
    Is the GPS antenna in the position I recommended or is it still just below the air vents? If the GPS is locking on properly, there should be no issue with speed reading. Mine works perfectly fine, and I always rely on it rather than the slower VW speedo.
    Also GPS software has an auto start function, it's under setup -> system I think. I'm sure I mentioned it somewhere in my instructions, but I will go check later.
  2. #282
    Jun 2011
    Sydney NSW
    Quote Originally Posted by DkN View Post
    I will make the request. On Audi OEM systems the volume drops (half?) when reversing instead of muting, what would your thoughts be on that?
    That is what my MY11 Caddy Maxi Life does.
  3. #283
    Jun 2011
    Quote Originally Posted by starionx View Post
    From memory, the music screens don't constantly show the volume. It only shows briefly when you change it. This would be what I would expect on the Nav screen as well.
    Yes that is how the volume bar behaves but it is a rather fat bar - although the area it blocks on the map should still be behind your car so it's probably not a big issue.
    Quote Originally Posted by wai View Post
    So would the preference be volume drop or no volume drop? I found the volume drop annoying at times on the Audi but I suppose if you're blasting music you may not hear the sensors otherwise.
  4. #284
    Jun 2011
    Sydney NSW
    Honestly VW, what's the point of having a removable plastic cover that is so hard to remove?
    Unfortunately these days, cars are designed to be made as cheaply as possible and not necessarily for repair or modification. It is much quicker to have clips that snap in than covers that have to be screwed together. They are working down to a fraction of a second to cut costs. Their attitude is that if the owner wants to take it apart, then that's their problem.
  5. #285
    Jun 2011
    Sydney NSW
    My preference would be for a volume drop as it also is an indication you are still in reverse.
  6. #286
    Aug 2007
    I actually had it on top of the dash for testing and I was on cruise control doing 45km/h. At one point it was showing 55km/h. It was only a 5 minute drive. I'll have to go for a longer run to see how it goes.
    CW MY12 5Dr manual GTI. ANS-810 head unit.
  7. #287
    Mar 2012
    I prefer no volume drop, but a Config option would be best.
    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
  8. #288
    Aug 2012
    United States
    Any new firmware updates coming along with any fancy fixes?
  9. #289
    Jun 2011
    Quote Originally Posted by DSGVW View Post
    As I said they are fixing the new iPod browsing interface before releasing the new firmware, I have asked them to fix a couple of the small things for the USB/SD music interface while they're at it, if they could squeeze them into this release. Should be a fairly significant update when it arrives.
  10. #290
    Aug 2007
    I hope they fix the 'muting' of the the first second of a new song when in 'random' mode (usb/sd). A tad annoying.
