Originally Posted by
whiskywallah
Hi DkN,
There is a 12v out to power the antenna.
But I see no 12v trigger out to turn on/off an external sub amp.
Can the antenna power feed perform both functions?
Is it switched with the unit's power?
By that do you mean all you need is that the amp turn off when you leave the car, and turn on when you turn on the ignition? If so then yes, you can simply use that one.
