Page 144 of 149 FirstFirst ... 4494134142143144145146 ... LastLast
Results 1,431 to 1,440 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1431
    Sep 2008
    Melbourne, Australia
    Since updating to M140 I have had a couple of canbus issues. I realised the steering wheel buttons were not working anymore. I went into the hidden menu and changed the can bus module from can-s to can-v. Now I have working volume and mute buttons but the right hand set isnt recognised. ie. input select / track change.
    Any one had the same?
    Baz
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  2. #1432
    I have a ANS-620 navi HU in fitted my 2008 pre-facelift Skoda Octavia VRS CR170 a good while back and later a Maxidot retrofitted, too.
    When going from the MFD to the Audio menu, the Maxidot completely locks itself to said menu, and cannot be changed without either fuse removal, or battery disconnection. I'm pretty sure this isn't normal, and no amount/combination of button presses unlocks it.
    Hmm, whilst skimming this thread, which seems to have a lot of information about these units, and there seems to be a hidden menu with various CANBUS options.
    Listed are: CAN-S, CAN-V, CAN-X and CAN-M (which is the current selected option).
    With previous VCDS scans, I've always had the following CAN gateway error listed (since the HU was fitted). Could this be due to the wrong CAN setting in the HU? Errors are gone with the OEM HU installed.
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533__Gateway H16 0202
    Revision: H16 Serial number: 2700K087020CCB
    Coding: E9807F060002021303
    Shop #: WSC 11679 000 1048576
    VCID: 3561C75F5CB4ADB6775-8060
    2 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 116
    Reset counter: 110
    Mileage: 94426 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:50:09
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 150
    Mileage: 94426 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:52:02
    Or could it be an issue with the firmware? This is what I get when I touch the screen on the mid-far left in the AUX IN menu:
    Version
    BSP: ANS510AS.611
    MPU: ANS510AS.M93
    Servo: 8B37.DL30.1200W.100414
    MCU: ANS510AS.121123.m1.T1
    BT: 20120512
    MST701: 6.2.07
    Region code 9
    Cheers.
  3. #1433
    Sep 2008
    Easy way to tell if it the canbus code is to see if the steering wheel buttons work. If they did, and now dont ...
  4. #1434
    I don't have steering wheel buttons - do you mean the stalk controls?
  5. #1435
    Sep 2008
    No
    Some steering wheels have the volume controls duplicated there etc. If they stop working the can bus is not getting there.
    Also some head units get that or similar code as they dont get recognised as an VW unit thru the canbus. If it works leave it alone
  6. #1436
    Jun 2011
    Sydney NSW
    I hope this is the right area, but I have a question on iGo Primo on these units.
    When you enter an address to find, it comes back with a route, and then depending on the route, you will see a number in brackets on the Go button.
    I assume that if it is say "Go (6)", it would mean that there are 6 alternative routes. That being the case, how do you bring up those alternative routes and pick from them?
    Thanks.
  7. #1437
    Quote Originally Posted by wai View Post
    Thanks.
    I thought it was some kind of countdown timer? What happens if you press it?
  8. #1438
    Also, is it possible to retrofit TMC to these units?
  9. #1439
    Jun 2011
    Sydney NSW
    Quote Originally Posted by HiSteveLoveTheShow View Post
    I do not believe it is a countdown timer as the number varies depending on the destination. As for pressing it, you have to to get the navigation to start.
  10. #1440
    Sep 2008
    Generally it is the time until it starts navigating. Allowing you to cancel if you want. Pressing it should start the route calculation.
    All you need is here. Including latest programs, maps, Camera poi's etc.
    Fixmygps Mk III - GPS Navigation Made Easy - Help with IGO 8, 8.3 & Primo Software
    Im a Mod on that site.
    Bazzle
