Page 138 of 149 FirstFirst ... 3888128136137138139140148 ... LastLast
Results 1,371 to 1,380 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1371
    Mar 2013
    Greece
    You don't loose anything to give a try the D1 MCU. There is also the option to disable OPS in the main menu. In the old firmware M99 wasn't doing anything but I haven't try with M140
    ANS-810 / ANS-510 (PROPER RNS-510 alternative)-4-jpg
  2. #1372
    Apr 2013
    Helsinki
    Maybe I will try the D1 at some point. I don't want to disable OPS since I am using it. I just don't want the camera screen.
    I still believe it is a bug though. The OPS works fine when switching to reverse once and staying with it. It is only the second time switching to reverse (i.e. if I need to move forward a little while parking) that pops up the camera screen... I see no reason whatsoever why it would have been designed to work like that.
  3. #1373
    Mar 2013
    Greece
    Yes you are right, I don't have OPS nither RVC and when i was on reverse pop up camera was on.
    With the D1 MCU its OK for me
  4. #1374
    I've ordered the ans 810 already and have had some dialogue with sandy but I have some questions. Reading this whole thread was a long slog!
    the cars it's going in is a uk 2011 passat b7
    id like to update the firmware when it comes, it seems the latest is the speediest and most bug free. I'll probably pay up with sandy for that but what if the device goes EOL soon?
    my car has front and rear parking sensors and I want the display on the head unit. Most of the bug talk is around ops. In layman terms is there a special software to run to only see the front and rear sensors? I've no intention of putting a camera in.
    When we travel longer distances I put those DVD players in the back for the kids. They support video in and one does video out. I'd like to run the right cables to the rear floor well or centre console to allow me to connect the rear players and control the DVD from the head unit. I guess that's possible? Probably need to order some extra cables though.
    what maps will come on the sd card for the Navi? Is it worth upgrading?
    think that's it for now.....
    jon
  5. #1375
    One thing maybe to contribute is that it's possible to connect a Raspberry Pi to this head unit that can run full XBMC or a PC(Linux) if you like. That opens possibilities and it runs on 5v and is the size of a credit card
  6. #1376
    Dont waste your time
    Quote Originally Posted by Jon0881 View Post
    Tried running a raspberry PI and whilst it worked its not a good solution, the 5V power out from a cig lighter is very flakey and not enough to fully power the PI so it kept resetting itself.. if you could get a more stable supply it would prob work but its too much like buggering around...
    As for the post above regarding front and rear parking sensors they will just display anyway I believe.. my rear ones only work when in reverse so have no idea how the front ones work (assume they will just display the car on screen when you are close to something having engaged reverse first maybe?? either way the whole OPS thing is a minor pain but if you give it a few seconds between gear changes its usually fine...
  7. #1377
    jon
    Def worth upgrading the maps, bit of a pain but its easy enough done, just back up the original SD card first so you can always roll back..
    As for your dvd question for the kids, sounds easy enough, but as you are already behind connecting a video out feed, why not just connect another one at the same time? the ANS has 2 video outs for head rest monitors.. run one down each side of center console and up to the top of the seat, easy done... and better than having a lead go between the 2 screens...
  8. #1378
    Apr 2013
    Helsinki
    Its only AUD 25 so don't worry too much and get the support from Sandy. According to my experience people at Audiosources don't speak English very well.
    The OPS works fine without camera or "special software". I just installed the D1 version and now the camera screen stays away as it should (It is basically wrong firmware for my unit but that is just normal Audiosources software engineering and since I don't have the camera it makes no real difference)
    Mine came with iGO8 + old maps. Just go to navitotal.com (or other similar site) and put together whatever software + maps package you want. I am using iGO Primo 2.4 + Navteq Europe Q4/2012 maps at the moment.
  9. #1379
    Hi,
    ok ok I got my ans 810 today. Super fast delivery but I have a problem. The unit doesn't look like the picture. There is no printed text around the mic volume etc. the sd card slots are covered with a cap and both are empty. I thought it was meant to come with an sd card? The fakra cable it missing too! Ggrrrrr
    jon
  10. #1380
    May 2013
    Perú
    Hello to all.
    I have a quick question and I hope to find some help here. I´ve ordered ANS610 with 3G and I am not able to get it connected.
    I am from Peru and have tried different APN settings found on forums with two different internet operators and I only get Error:679 and Error:633
    Does anyone have experienced those kind of errors? Can anyone with no problem with 3G post the settings?
    Maybe I am formatting wrongly the text input... or can give a clue of whats going on....
    Sorry for the bad english.
