Page 134 of 149 FirstFirst ... 3484124132133134135136144 ... LastLast
Results 1,331 to 1,340 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1331
    Sep 2008
    Melbourne, Australia
    MPEG is not important. Only reads the code IF there is a signal present.
    Baz
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  2. #1332
    Mar 2013
    Greece
    Maybe it's better to try the M99 first so you can update also the MPEG which I think it's not included in the latest M140.
    I don't know what is the "510as.130112.m1.t1". The critical is to have "M" firmware and not "V", so go on and if you have problems with the D1 you can always try swap to D0
  3. #1333
    Jan 2014
    Newcastle, NSW
    Can you set these up with a Skoda start screen rather then VW
  4. #1334
    Jan 2014
    Rome
    Hello everyone, I'm Italian and sorry for the bad English. I have an
    ans510 with firmware M136. I'm very glad but I have two questions.
    I have a sd card 16 giga, reads files but sometimes if I try to turn
    back the sd freezes and I have to go to another function.
    ops sistem screen only work with the system radio turned on. However i
    shifted the reverse gear but the radio is turn off, i don't see the
    imagine of the car on display, but I only hear the sound of ops. It 's normal? i have a
    skoda yeti 2012 and with the M136 firware I see all the functions about
    car information.
    Thanks
  5. #1335
    Jun 2011
    Sydney NSW
    Quote Originally Posted by sundark View Post
    car information.
    Yes, it's normal.
    I did mention that I thought it had been fixed a few posts back, but I spoke too soon. No real problem as the sound warning is still there.
  6. #1336
    Oct 2012
    Newcastle NSW
    Clearly there is something wrong with the M140 update, unless I am missing something! In the end I just updated from the second step (I was still on M94) and it worked OK from there.
  7. #1337
    Mar 2013
    Greece
    Yes that's right, you update the second part (GPS slot), because there is nothing to update in the first part.
  8. #1338
    Jan 2014
    England
    Hi everyone,
    I have an ans 510 fitted to my mk5 golf gt running firmware V96 and was wondering what is the latest firmware available. There is a lot of posts about the latest M firmware but none about the latest V firmware. Does anyone know what is the latest V firmware?
  9. #1339
    Rivol et all,
    Ive found an older firmware on my laptop but have no idea what version it is.. Im assuming its the M99 that I didnt upgrade to!! but have no way of knowing, the date of creation was may 2013??
    Also when I extract it it seems to have more files than the current firmware, 16 files vs 12 files for the new one..
    I have attached a pic of the older firmware I found.. any ideas if I should do this first then move on to the M140?
    ANS-810 / ANS-510 (PROPER RNS-510 alternative)-capture-jpg
    My main question is what should I do first and what are these additional files (966R.mhs/Program 966XF.mhs/Program)
  10. #1340
    Mar 2013
    Greece
    Yes that should be the M 99, I have the same here:ANS-810 / ANS-510 (PROPER RNS-510 alternative)-ans-3-jpg
    It has more files in than the M140 (probably the MPEG) and what so ever, that's why I told you maybe it's better to go with M99 first.
    Perhaps you could add the missing files from 99 to 140 and give it a try or go the safe way, first M99 and then the M140. The installation of the M140 takes you to the second part (GPS slot) which means there is nothing to update in the first part.
