Page 132 of 149 FirstFirst ... 3282122130131132133134142 ... LastLast
Results 1,311 to 1,320 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1311
    Mar 2008
    Chatswood, NSW
    Quote Originally Posted by rivol View Post
    I have Golf MK5 2005 and I have no issues with M99, is there a reason to update to M136 ?
    Same here, I'm actually using the version before M99, I didn't bother upgrading last time because a few people on here had issues. Hence why I am hesitant about upgrading to 136 without seeing a log or hearing some feedback.
    MKV GTI
  2. #1312
    Any updates on the OBD function at all and if the ans810 will support it...?
    I have been trying with limited success to get some version of android torque to work via the RCA in on the back of the stereo but this involves so many cables and a signal converter from HDMI to RCA that I got fed up with it and removed it all..
    Im now contemplating selling my ANS and going to a clone Chinese one that uses android as its seems to be an easier option.. why Audio sources choose to drag their feet is beyond me
  3. #1313
    My rear view camera badge worked today in the 40 degree heat. All throughout the day too. Let's see if it still works during the heat wave week.
  4. #1314
    Sep 2008
    Melbourne, Australia
    Quote Originally Posted by enigma32 View Post
    Thanks for the link for the Nav maps Bazzle. Had a quick look and there seems to be a few versions available. You recommend any particular one for the ANS810? (Igo Primo, Igo 8.3 etc?)
    Latest Holidays, Port Douglas 13 (Primo 9.6.5.254477) NT and Sensis maps, mapchanger included.etc etc.
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
  5. #1315
    Oct 2012
    Croatia
    hello,
    todaj i updated my vw passat with ANS_M140 and now i have car information in settings and displaying some odb informations, but OBD menu is prohibit in main menu , can i enable this ?
    thanks sandy
  6. #1316
    Can someone point me to the instructions for updating the firmware etc and how i find out what version im currently running? I have the ANS810 and have been sent the M140 update.. does anyone know what it brings to the party for Skoda Octavias? I have a 2007 VRS
  7. #1317
    Sep 2008
    Update Steps ANS-810
    You can check your firmware version by going into the Aux In screen, then pressing and holding the centre of the bottom of the screen until the firmware version screen shows up.
    step 1 . put into gps slot and turn on (it will automatical update BSP/MPU )
    step 2. after BSP/MPU update finished then extract the card and turn off
    step3. put into GPS slot again, and long press lown right at Aux-in then chose "yes"
    step4. it will turn off automatically and then extract card
    step5. turn on the unit , put the same card into the SD slot, and it will update MPEG4
    step6. after finished update MPEG4, it will turn off automatically after that extract the card
    step7. turn on , click into the AUX-IN model , then click "setup", back to default setting
    OK done
    AND
    ANS series firmware upgrade instructions
    Requirements:
     SD card, 4GB or less, formatted as FAT. IMPORTANT – must be formatted as FAT and not
    FAT16 or FAT32, and the card MUST be 4GB or less, or it will not be able to be formatted as
    FAT. Simply connect your SD card to your computer or laptop, right click on it from “My
    Computer”, choose format, and select the “FAT” option (default is usually “FAT32”).
     Current firmware version
     About 20 mins spare for the first time, allowing for mistakes and double checking
    1. To determine which firmware you require, you must find out what version you are currently
    running.
    2. Go to the main menu, and select “Aux In”. On the Aux In screen, press and hold the very
    bottom of the screen, in the centre. A screen like the one below will come up (you can tap
    anywhere on the screen to exit out of it):
    3. Take note of the BT row. You will need to choose the link to the correct firmware depending
    on what your BT version is. There are two versions, 20111115 and 20120405.
    4. Before you embark on the firmware flash, just as a precaution in case the system language
    resets itself to Chinese, take note of what buttons you need to press to get to the language
    setting, to save yourself some trial and error later.
    Page 2 of 3
    5. Once the update file is downloaded, simply extract the contents to the root of the SD card
    (this means in the top most level of the SD card, with no folders).
    6. Once the SD card is prepared (again, there should be no folders, all files should sit in the root
    directory of your SD card), take it to your unit, turn it on, and insert the card into the MEDIA
    slot. The unit will automatically switch to SD card – if it does not for some reason, do it
    manually.
    7. Wait a few seconds, and a pop-up message will ask you if you want to update firmware, with
    two options, “MPEG” or “cancel”. Hit MPEG and wait.
    8. When the unit is done flashing, the same pop-up message will come again but in Chinese,
    with the same two buttons. At this point the MPEG flash is complete and you can just ignore
    this screen and take the card out of the MEDIA slot.
    9. Put the same card now into the GPS slot. Switch to the Aux In screen again. This time, press
    and hold the bottom right corner of the screen until a pop-up message comes up asking for
    confirmation to flash firmware. Hit ok and the process will begin.
    10. Wait until it is finished – the unit will turn itself off. At that point, simply turn the unit back
    on, and you will see a screen similar to below:
    11. The process will take about 5 minutes and may look like it is stuck on a certain line.
    12. If you get stuck at the “CREATE MBR” line for longer than 10 minutes, you did not format
    your SD card to FAT. Double check again, that it is indeed formatted as “FAT” and not
    “FAT16” or “FAT32”.
    13. You will not brick the device (make it unrecoverable) by pulling out the SD card during this
    screen. When you come back with the correct files and correct SD card format, put it back in
    the GPS slot and turn on the unit, it will simply re-flash everything.
    14. After the update proceeds past this screen, you will be brought to a white screen with text in
    the centre saying that the device is updating and do not turn it off. When the message
    changes to success and please reboot, simply reboot the device, and you’re done. When you
    turn the unit off for the reboot though, remember to take the update SD card out of the GPS
    slot before turning it back on, otherwise it will perform the update again.
    Page 3 of 3
    15. You may wish to calibrate the screen afterwards, although I have not found any noticeable
    issues. To calibrate the screen, press and hold the hardware “menu” button. Tap anwhere
    on the screen after calibration to exit it.
    16. You will lose your radio presets and some (but maybe not all) of your settings. Settings that
    are lost may include driver door side, navigation auto-start, phone auto-answer, ASP settings
    and navigation software path etc. It may be a good idea to browse through the settings
    again and get them back to the way you like them, and it would be essential to set the
    navigation path again, otherwise you get an error message when you try to run satnav,
    telling you the GPS path is not set.
    17. That’s about it, have a play around with your new firmware and let me know if you have any
    feedback 
  8. #1318
    Jun 2011
    Sydney NSW
    Interesting.
    I just went through the process, but when I put the SD card in the unit, it switched to the SD screen but sat there like it was expecting to play music.
    After the problems with the M136 problem, I was told then to just go through the second part of the process, so I switched the upgrade card with the GPS card and pressed the bottom right of the screen in AUX IN. It asked if I wanted to confirm the upgrade to which I answered yes, and it went away did what it had to and shut down.
    I started it up again and all is ok. I lost my radio stations (expected), but had no issues with the language.
    Could this be because I had previously tried the M136 upgrade?
    So far, so good.
  9. #1319
    Quote Originally Posted by wai View Post
    Interesting.
    So far, so good.
    Which firmware did you upgrade to? is it the M140? and if so are there any new features worth upgrading for over the previous ones? (also did you follow the guide above?)
  10. #1320
    Quote Originally Posted by Szymon View Post
    Eeek! I just did a reset to defaults from the menu, and after restarting the radio lights no longer light up! Also, the MFD shows the audio as "OFF", doesn't display radio or anything, and the car information display shows no readings (0rpm, 0kph, -40C temperature, etc). Help please?
    Szymon, did you get information displayed on your screen when in OBD mode then? im guessing it must have been enabled in the M136 firmware? incase your question hasnt been answered either, there is now M140 available so you should be getting that soon.
