Page 130 of 149 FirstFirst ... 3080120128129130131132140 ... LastLast
Results 1,291 to 1,300 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1291
    Nov 2013
    London, England
    Thanks Hans - so I guess I will live with the reversing.
    Does your SD card do the same thing I described with mine? I'm going to try another SD card to rule out it being a problem with the card, but it's a fast card and seems to read/write well on the computer!
    If I could ask, what firmware version do you have? Should I be worried that mine seems to be different to the M99 discussed here? Maybe it's a regional thing, with M99 being the current Australian version?
  2. #1292
    Nov 2013
    London, England
    Ooooh! Setup, System, scroll up and there is a setting for "Camera Volume" which is set to "Mute" by default. Change it to 5, 10 or 15 and the volume while reversing is set to that level. I have set it to 5, so the radio goes quieter while reversing, but doesn't turn off. One problem solved!
  3. #1293
    Apr 2013
    Helsinki
    Quote Originally Posted by Szymon View Post
    Your firmware seems to better than mine then (M99). I want M136 too...
    I have not had any issues with SD card playback except the fact that the songs ar not in the right order in folders.
  4. #1294
    Mar 2013
    Greece
    I had the same problem with the reverse because I don't have reverse camera, so Sandy send me a firmware that disables the OPS. I have the ANS 610.
    Better wait for Sandy to return from honeymoon and he will give you a solution.
  5. #1295
    Nov 2013
    Canada
    Finally installed my ANS810 and RVC. RVC took over 3 wks to get to Canada from Hong Kong! This is the first shipment from HK to Can I have experienced such long shipping time (tracking was provided).
    The ANS810 I have, has a CAM PWR lead that only gets power when R is selected on the shifter. It gets the info from CANBUS. I used it successfully to power the RVC camera. No tapping of the Rev light circuit required. All it took was to run a wire from the CAM PWR lead to the positive of the RVC, ground the negative on the RVC to the ground point in the trunk lid. Video signal wire from RVC to ANS810. Done.
  6. #1296
    Jan 2011
    Bundaberg
    Latest Maps for ANS-420?
    Hi
    What are the latest maps available for the ANS-420?
    Mine are from Jan and the unit is starting to give me warnings about my maps being out of date.
    Cheers,
    Scott
  7. #1297
    Jun 2011
    Sydney NSW
    Same here on my ANS-610.
    I think it's time for new maps
  8. #1298
    Jun 2011
    Sorry guys I have the new map update sitting here with me I just haven't had time to send it out - I've had a computer upgrade and would have to put together the ANS customer email list again and right now the DNS series group buy is taking up all of my time. I'll aim to send out that update by this weekend.
    Regarding the firmware, I do have M136 as well though I was initially told when given it that it was made to be compatible with new features in the new Passat. I'll confirm the firmware is okay on other cars (which seems to be the case if units are just shipping with it).
  9. #1299
    Nov 2013
    London, England
    That's great, thanks for confirming the firmware numbers DkN . It does seem the firmware works well on my 2009 Passat, it does seem slow to react to button pushes sometimes (e.g. when you push the nav button to turn the nav off so you can see the radio screen, sometimes you have to wait a while or push a couple of times), but in general it's OK.
    I didn't know about the DNS when I ordered the ANS here in the UK, else I'd have been a member of your other group buy...oh well, maybe I'll upgrade in a year or two!
  10. #1300
    Jan 2013
    Melbourne Vic
    Sandy, appreciate that you have been kept quite busy with the DNS launch, but please try and find a few minutes for us ANS folks who have been patiently waiting in the background. A firmware and map update has been a long time coming and would be very welcome.
    (PS more importantly make sure you always make time for the new Mrs Sandy..................)
