Page 129 of 149 FirstFirst ... 2979119127128129130131139 ... LastLast
Results 1,281 to 1,290 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #1281
    I just got the dns 810 and it has so many bugs. The sd card want play songs all the time. I can't get the blu tooth to sinc with my galaxy s4..the rear camera spent work.. .then the fm radio won't work after selecting sd..
    so I will send it back. Since you guys own a ans series. Should I order that? Or look for another manufacturer like eonon?
    Does the ans have bugs like I described in the dns?
    T
  2. #1282
    Pacific Paradise QLD
    Quote Originally Posted by raymondtrudeau View Post
    T
    Going from ANYTHING to an EONON would be jumping into a very hot fire. Read the threads through the audio section about them.
    I don't think anyone was happy with them.
    You get what you pay for.
    Spend a grand and get an RNS510 and while the Satnav is crap the rest is ok and all integrates with the car
  3. #1283
    Apr 2013
    Earth
    Hello, I hope you guys can help me.
    I have an ANS-810 that I got from AS directly (I emailed them but no answer) and I can't select the right car. No matter what I choose it always display the skoda (I have a GTI).
    I tried to reset the settings on the setup screen or even press the reset button under the GPS sd but no lucky.
    Do you guys have any ideas?
    Thank you.
  4. #1284
    Hi DKN,
    Has there been any news on the ANS810 and OBD at all... or what the latest firmware is?
    Thanks
  5. #1285
    Apr 2013
    Helsinki
    LGSilva,
    Do you mean the OPS screen or door status screen? Door status screen will show BMW picture regardless of your settings but the parking sensor screen should work according to your car model selection.
  6. #1286
    Quote Originally Posted by LGSilva View Post
    Thank you.
    Did you sellect from here:-
    ANS-810 / ANS-510 (PROPER RNS-510 alternative)-b9s8xda-png
    Attached Thumbnails Attached Thumbnails ANS-810 / ANS-510 (PROPER RNS-510 alternative)-screenshot_402-png
  7. #1287
    Nov 2013
    London, England
    Hi there,
    I've read through this entire thread (which took quite some time I can tell you!) and I wanted to check something about the new ANS810 I've bought. The vendor (iceboxauto in the UK) assured me that I will get a unit flashed with the latest firmware, and the BSP matches that reported as latest on this thread, but the rest doesn't. My numbers from the menu are:
    BSP: ANS510AS.612
    MPU: ANS510AS.M136
    MPEG:
    Servo:
    MCU: ANS510AS.130806.m1.D0
    BT: 20120512
    MST701: 7.0.098
    Region code: 9
    I can find no report of a M136 version - is that newer than the M99 by virtue of the number being bigger? Why does no-one else seem to report it? Also, the 130806 seems higher than that reported as current. Should I be worried?
    I do have a couple of odd issues I can't seem to get past. Firstly, when going into reverse, my audio cuts out until I go out of reverse gear. The screen stays on the navigation, but no sound. I've disabled OPS in the menu, and it didn't seem to help. I don't have OPS or a reversing camera fitted at all. Are there any other settings I might need? Could this need a different firmware? Second, when playing music from SD card, the sound seems to cut out and jump every so often. It's not constant, but once every few minutes, it just dies and then starts again. Any thoughts?
    Many thanks for any help you can provide
    -simon
  8. #1288
    Nov 2013
    London, England
    Eeek! I just did a reset to defaults from the menu, and after restarting the radio lights no longer light up! Also, the MFD shows the audio as "OFF", doesn't display radio or anything, and the car information display shows no readings (0rpm, 0kph, -40C temperature, etc). Help please?
  9. #1289
    Nov 2013
    London, England
    Ok, removing the car battery for a couple of minutes appears to have gotten the CAN bus connection going again
    Would still appreciate it if anyone could give a response to my other questions on Firmware, audio while reversing and SD card though!
    Many thanks,
    -simon
  10. #1290
    Apr 2013
    Helsinki
    Szymon, reverse gear will mute audio. Simple as that.
    Regarding other features ANS series is far from bug free but it works OK most of the time. OPS for example does not work if GPS is in use, RDS functions on radio are a joke, switching between GPS display and radio/sd card/cd may or may not work etc.
