Originally Posted by
JasonTheLucky
I'm interested in the 710 or may wait for the new unit, I have a 2007 GTI MKV and after reading the entire thread have a few questions
Does ANS-710 fit in GTI.. I assume it does but AudioSources website only lists it with the Toureg?
Does a MKV have a GPS antenna coming from the shark fin? It seems everyone wires up the antenna that comes with the unit and I have no probs with that, but if there is an existing GPS antenna in the shark fin that seems like it would be the best. MKVs with a factory nav unit must use the shark fin as they don't have an indash antenna?
Does the backup cam work in a MKV
What is the resolution of the 7"?
Anyone run TomTom or American Users where do you buy iGo Software and Maps, looks like it only runs on Iphone from website? It looks like if you buy from this guy or AudioSources you get maps and software (depending on what country you are in)
ODB Functionality.. does that allow you to see your CEL Check Engine Light Codes and Clear them or do you still need a VAGCOM tool for that?
The 710 is for the Touareg and will not fit in a Golf. The 7" Golf version is the ANS-610.
I'm not entirely sure if having a shark fin automatically means you have the GPS aerial, but if you had factory navigation, then yes the shark fin would have the GPS aerial. If so you can use a FAKRA to SMA adapter and connect it to the unit. Alternatively, wait for the new unit and it will have stock FAKRA connections.
There are reverse cameras to suit Golf 5, you can choose LED licence plate type or the VW badge type camera.
The OBD can read and clear DTCs but in my experience with most fault code readers they may not be able to read all fault codes. I don't think it can clear a CEL - it's not a replacement for VCDS, it's more used to show additional info and do acceleration & fuel consumption calculations.
