... and that would be when? :wink:
Printable View
DO you know if there are going to be any european distributers?
this is what my rvc shows...
http://hids4us.com//host/20130405_195522.jpg
is the red arrow pointing at the hard coded lines?
Yea..that static lines was pointing you the distance of if any object at the rear to your bumper, the red static line was the closer to your bumper and some will be shown as this;
http://www.vwwatercooled.com.au/foru...33159a_c-1.jpg
Hi Everyone,
I know this has been discussed before but not sure if a solution was found. My ANS-810 has a hard time reading my 32GB SD card. Some days it reads just fine, others it says "BAD SD" and others it loads but then says the track is 12:15-12:15 and nothing plays and no menus/folders are available. It used to happen every other day, now it is most every drive. If I pop the SD card out or restart the radio, or switch from radio back to SD usually i can get it to go but some days it takes a combination of all these or 2-3 resets of the device. Then it picks up like nothing ever happened. Is my card going bad? Maybe I will try a new one or smaller one and see what effect that has.
Just wondering if anyone with a similar experience can chime in.
Thanks!!
Maybe it doesn't mean anything, or it's already how you have it, but you can try formatting it in FAT (not FAT32). I think it's something related to formats...
You can only format <4GB cards in FAT I think. I had to do this for the firmware updates but music should be fine I thought..
