I'm not sure if anyone would give you 100% guarantee, but, you shouldn't have the battery drain issue with that unit.
@DkN
Because I'm interesting to purchase the ANS-610, I want to ask if there is any drain battery issue when installing ANS series in MKV GOLF or JETTA earlier than 06/2006 model. These models they have stock unit RCD 300/500 and if you install RCD 310/510 there is definitely drain battery issue because of the older can bus. These cars they use the type 1 steering wheel buttons like the picture below.
So i need to be 100% sure before i make the order.
Thanks in advance
Alexis
As I mentioned in the first post there will be no battery drain whatsoever.
The unit has been installed on older Golf and Jettas with half screen MFD without any issues.
DkN, if i switch my current climate controls in my 2008 R32 to the MK6 one, will it work with the ANS810 or the new units?
Thank you,
Na'el
I cut out a matte screen protector from an ipad piece I had laying around. Works "OK" for me.
Give it a go and if you dont like it , remove it. Easy to play with.
Bazzle
Prev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
The climatronics replacement is just a drop in, it doesn't change the fact that your CAN-Bus does not store air con information. You'd have to change your CAN-Bus to mk6 for it to work, though I don't know of anyone who's done that so I don't know if there are other consequences for doing that.
I just made the order for the ANS-610 directly from AS since I'm from Greece, I hope i don't have any compatibility problems
Can somebody give me the exact measures of the LCD screen so i can order an anti-glare film from Quality Screen Protectors for Any Display by Clarivue
Thanks in advance
Alexis
OK, I was just wanted to be ready, it will take some time to arrive and would be easier to do this job on the desk before I install it.
Thanks anyway
Thanks DkN.
another question please, will any of these units fit old cars? am asking about Skoda Fabia 2001
