About the SD Card issue, it has happened on my own unit but it seems to be a rare bug. This glitch, when it happens, like to do so either on boot, or on the 3rd song that you skip to after you turn on the unit. It's been hard to pin down and you are the only other person so far that I know of that has it, which is why it hasn't been resolved yet. When it happens though, you just need to switch to another source like Radio and switch back, and it should reset. If you find the problem keeps occurring, do a soft factory reset through setup -> general, take out your media SD card, re-flash the latest firmware, let the unit boot into radio, then re-insert the SD card.
I am also pushing for Audiosources to perfect the software at least in its current form, this seems more likely now that they are not discontinuing the current generation.
