Also a pointless post!
Printable View
Just thought I'd offer some feedback.
I got back to Sydney after the holidays and did the upgrade to both the firmware and maps.
Once I got the Sandisk MobileMate I was able to get the files on to the mapping microSDHC card. All went well with the map upgrade.
I formatted a microSDHC to FAT and then downloaded and extracted the files onto it.
I did make note of how to get to the language section as suggested and I did need it. A tip for anyone is to just note the column and row for the buttons, spreadsheet style. One thing I did not do was to note the radio stations as they all get wiped :-(
The upgrade went OK. I reinstated the language and then had to try and remember the stations I had. I have now made a list of stations for the future.
hi DkN,
Are you able to give any more info on the new units yet?
Thanks
I drove a Golf MkV. This firmware IMO has made the RVC functionality worst. My unit hang couple of times to the point where I need to power off the unit. The RVC is unusable if you have bluetooth, navigation on, or both.
http://img651.imageshack.us/img651/5...0103161927.jpg
Unit freezed
http://img580.imageshack.us/img580/5...0106100001.jpg
RVC when unit not fully boot up to USB
http://img825.imageshack.us/img825/9...0111141935.jpg
RVC when using bluetooth or Navi
One thing I have noticed with the new firmware is that when I start the car, it goes to the radio rather than the sat nav. I have to press the NAVI button. The previous firmware remembered what was last being used. Not a biggie as the satellites hook up much quicker.
While I am here, I went fown to Bendigo (from Sydney) for the Christmas break with the previous firmware (only did the upgrade when I got back). One thing I noticed was the system switching between Profile 1 and Profile 2, all on its own. The other thing (even after the upgrade) is that even though I have named Profile 1 to something else, it still shows Profile 1 on screen.
I've not seen a unit do that before - it could have something to do with the MCU update. I should get a new update soon and hopefully that will fix it, otherwise you may have a faulty unit.
Satnav autostart is an option under setup -> system. It gets reset by a firmware flash, that's all.
Not sure what you mean by profile - are you talking about the navigation?
Not sure how you do the wiring connection of your reverse cam. This link was useful to me: How to install OEM backup camera on mk5 mk6 VW Golf or VW Jetta Sportwagen TDI JSW
Especially this info from the link provides.(This requires a permanent 12V supply with a 5A fuse, don't attempt to use an ignition fed 12v supply otherwise unpredictable results will occur.)
I'll reset the system to get the navi come on.
The profile is the navigation profile. I presume it is the general settings that you can setup for different preferences. When the navi system starts up, there is a black "jelly bean" that comes up anouncing Profile 1. While driving to Bendigo (and on return), I would suddenly get this black "jelly bean" anouncing Profile 2 and then back to Profile 1 and back again. Nothing really changed, just this was displayed.
Well just got to the point where I am considering some mods to my 2011 CC. Main upgrade is to install a RVC, but reading through the great info in these forums, I am now getting giddy about the idea of replacing my head unit from my RCD510 to a more featured one which includes SATNAV with possibility of adding aftermarket RVC and not just OEM one. But from what I can gather, the ANS810 unit which looks quite impressive is just about to be replaced, and DkN is no longer stocking these.
I am not really interested in the OBD functions which look like a big feature of the soon to be released units, so the ANS810 would probably suit me fine as long as it fully integrates with steering wheel and MFD / AC like the stock unit does. I note that there has been improvements with Ipod functionality which is good - (I take it that you can list titles by podcasts now as well as albums, artists etc?).
Any other options I could consider? Or should I just wait and see what is just around the corner?
Thanks
