I dont have a remote amp but I used the Blue wire on my previous unit.
Just put a test light on the wire and trun the ign off (remove key)
Bazzle
Prev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
When is the obd2 device addon going to be released?
AFAIK the software development has all been completed, only thing left is to order the hardware - they've been extremely busy working on the new platform though so I can't be sure when that is happening.
Also yes iGo has its own fuel consumption calculator in which you manually enter km travelled and litres of fuel used. I've not seen the OBD fuel consumption module in operation yet so I'm not sure if manual calculation is an option, but remember your fuel consumption monitor can be adjusted via VCDS if you feel it is inaccurate.
I have had some issues lately (since the current firmware upgrade) where upon starting my vehicle (and the head unit starts) it locks onto the OPS screen. Except I don't have OPS fitted or the supplied reverse camera at this stage. The loom is not even plugged into the head unit. I have to restart the vehicle to restart the head unit to resume normal operation. Any ideas?
If you read back thru the threads you will see it is an add on module compatible with later software.
I dont see it as being that high on the list for this type of product personally. A kufatec is an alternative option that shows in the mfd.
Bazzle
