Quote:
Adjusting the Navigation Voice Volume
While the Navigation is on and a route has been programmed, the Navigation will
speak commands. While the Navigation is speaking, adjust the volume by turning
the radio volume knob. The Navigation volume will remain at this level and when
done speaking will return to the previous source (ie, radio) at the volume level set
for that source.
The main volume must be set above zero in order to hear the spoken directions. If
the radio is muted, the Bluetooth engaged in a call, or the volume knob has been
turned to zero, the navigation will not be heard but your visual directions will
continue.
I am not out at my car but from memory there is a settings section under the menu screen. Somewhere in the settings area I found the choice for two different voices. I am now just recalling that there may have been a setting for navigation volume too. Tomorrow I'll investigate when I am out in the car.
