Originally Posted by
whiskywallah
I agree with you. I've tried 3 or 4 different phones, linked BT to 2 different ANS and the quality is definitely not the best, and compared to hard wired is definitely worse. It's hard to describe the problem; there is a 'ticking' as you describe, but it also sounds like it's crushing the HF signal and maybe also something liketoo much gain (and no, turning down the phone does not help.)
I've tried iPhone4 and HTC phones so maybe someone who is happy with BT audio can tell us what phones they use?
The problem with BT audio is that most factory fitted BT systems and even a lot of upgraded BT systems like Kufatec, Parrot and others dont have Hi-Fi Audio as an intended function so they lack the necessary profile to use high quality BT Audio. Most cant be upgraded either as there are differing hardware processing requirements and different DAC's required as you increase the sampling frequency.
The BT A2DP profile sampling rate is specified as between 44.1KHz and 48Khz. (see updated post below for further specs)
Compared to my Manhattan dedicated BT Audio box I installed for my Aux in which has freq res 20hz to 22Khz (says 48K sample rate).
The same iPhone 4S sounds wonderful with the Manhattan and absolute crap with the Kufatec. (which is fine for voice! Just not Audio)
See my Macgyver thread below for info on the Manhattan BT box if your interested. The newer VW 9W7 F spec BT kit uses a higher sampling rate and high quality SBC profile for good audio quality as well as AVRCP for BT control/music navigation and Text support on the display.
IceGrey MY10 R36 Sedan - Sunroof - Tint - Ipod - RNS510 NAV - 9W7 BT - Voice Control - Adap Cruise - Lane Assist - Front Assist - Adap Chassis - Omanyts 19" replicas 255/35R19 ContiSport 5P
