Is the ANS-810 compatible with an 05 plate Golf GTI? Are there any battery drain issues?
Printable View
I'll try mate but if you ended up flashing the wrong firmware on it, I'm not sure if it's possible to fix it. Check your PM.
Interesting adapter - that looks like it would work. Although, what is the idea behind using it? The audio might work but music ID3 tag display wouldn't. If the USB is just there for charging, then the same thing can be achieved by using the normal USB cable provided with the unit, and then using a normal 3.5mm from the Aux-In slot, or just BT stream.
Dkn thanks for all your help i flash new firmware i have a screenshot from before with version of bt so that was not a problem, the unit has power up and everything is working great. Thanks for firmware i hope that in future there will be a lot of firmware realeses.
Cant wait for CAN menu !
Greetings from Croatia
Hi DkN,
I am looking at getting myself an ANS-810 soon, but was wondering about support for digital radio. In your first post, it mentions "A DAB+ solution is being worked on and I will update everyone when this is available - this should solve all radio signal issues." Does this mean that the units will be compatible with just a software update, or is there hardware involved also? If it is just software I will be ordering one upon your return in December!
Thanks, Ben
Hi, just bought a brand new ans510 for my jetta..installed and all, but the microphone for the handsfree bluetooth doesnt work properly..i can hear what they are saying, but they cant hear me. Does anyone else have this issue?
Mine works perfectly, ANS610 by the way.
