Page 40 of 149 FirstFirst ... 3038394041425090140 ... LastLast
Results 391 to 400 of 1488
Thread: ANS-810 / ANS-510 (PROPER RNS-510 alternative)
  1. #391
    Jun 2011
    Quote Originally Posted by starionx View Post
    Still on the old FW, but I believe any audio updates were IPOD related.
    The Random track (could be also Repeat... didn't check) function (usb/sd) does not 'stick' when the unit restarts. It always goes back to normal play. This, to me, is almost a deal breaker. If it's fixed with the new FW, I'll update asap. If not, I'm going to put my RCD-510 back in until it is.
    It is not fixed in the new firmware but I am pushing - there are a few technical programming niggles to sort out. In the mean time if this is a big issue for you it may be an alternative for you to use BT stream on your phone.
    Quote Originally Posted by kajkac View Post
    Where can i get new firmware ? Can somebody send link to mail kristijan.poljanec@gmail.com
    Thanks a lot !
    I'm happy to help if you have any issues with your unit but if you just want to keep up to date with latest firmware and news + support, I provide this for a one off subscription fee of $25 AUD.
    Quote Originally Posted by Big Jase View Post
    So I just installed the update.....and it did change everything back to Chinese! Can't see any other differences as yet. However, when I select Navigation - it says to create path.
    I go into settings, general and can see the primo sitting there. I have tried pushing the "Tick button" on every screen inside those folders but nothing works.....
    Any help???
    Thanks!
    The procedure should be identical to when you first set up the unit - can you describe in a bit more detail? If you choose select GPS file path, you should see a folder "Primo2", choose that folder, then swipe up (this is laggy I know) to scroll down the list until you see Primo.exe.
  2. #392
    Apr 2011
    Is there any way I could fine tune the radio, I kept getting this crackling sound every 2-3 seconds. Getting kind of annoying..
    Sent from my GT-I9300 using Tapatalk 2
  3. #393
    Jun 2011
    Quote Originally Posted by turbo81 View Post
    whiskywallah used a diversity antenna that seemed to work well for him, he linked it some pages back, or maybe you can try PMing him.
  4. #394
    Jun 2011
    Sydney NSW
    Quote Originally Posted by DkN View Post
    If I may also add, the antenna adaptors with dwo separate leads will not be able to be used with the plug that has double connectors on the car's wiring harness. Basically, when you place the two separate plugs side by side, their spacing is too great, and only one plug can have a locking peg.
    If your wiring harness has two sockets in a single unit, you will need something like the this one
    Audi VW Volkswagen Radio Dual Fakra Diversity Antenna Adapter [CT27AA56] - $19.95 : SimpleSoft,, Simple Solutions That Work!
    If you pick on the image you will get a full screen one and you can see how close they need to get and only one has a locking peg.
    The most frustrating thing (apart from the reception) is waiting for it to get here. I ordered mine on Oct 1, and it is supposed to have left the LA facility on Oct 3. I suppose they have to build and certify the aircraft :-^) and then there is Australia Post.
  5. #395
    Mar 2012
    Quote Originally Posted by wai View Post
    That depends on how hard you hit the connectors with a big hammer
    Tiguan MY12 118TSI, white, no frills..... Had ANS810 ... Note the HAD ..... Now got RCD510 supplemented by 7" Android TomTom mounted on a HoldMyPhone .... Upgraded speakers Vibe BlackAir front splits and MBQuartz 12" ported sub driven from Infinity Reference 5350a amp .... oh and added fun
  6. #396
    Jun 2011
    Sydney NSW
    Quote Originally Posted by whiskywallah View Post
    I was reluctant to use the "Irish Screwdriver" as when I was trying to get them both in, I could see the socket distorting quite a bit, and the last thing I wanted was to break it.
  7. #397
    Apr 2011
    Thanks guys, placed an order for the adapter. Got the same one as whiskywallah. Hopefully this is fix the issue.
  8. #398
    Apr 2011
    Hi DKN,
    Is there any updated firmware for unit BT20120512?
  9. #399
    Jun 2011
    Hi DKN,
    BT20120512 is interchangeable with 20120405.
    Also in response to someone's query about seat warmer display not showing a couple of pages back (posts here moving pretty fast these days), my technician says that they've confirmed seat warmer display to work on a Passat CC. The display probably just looks a bit different to the stock RNS-510 one? I cannot confirm myself since there is no A/C display for a mk5 Golf.
  10. #400
    Jul 2012
    Ay news yet on the obd function??
