hurruh so i finished the install myself. the wiring was a lot harder than i thought. i ended up cutting out the plastic at the back of the dash to get it to fit. i have no idea how i would of done it otherwise.
so... things ive noticed.. the DTV just.. dosnt work. its not really an intergrated part of the software. takes you to some chinese aftermarket thing with finger overlay.. but meh. no biggy. but yep scanned and scanned and could not pick up a single channel. not sure why
also. turning the unit on.....i cant quite work out its power up setup. if i put my foot on tbe brake and start the car .. it wont turn the unit on. if i turn the key and then start the c ar it will. hmmmm
the MFD just dosnt work. which i suspected it wouldnt. i presume it only works for CANBUS 2.0 and not 1.6 i might get an adaptor. i dont ahve an "audio" setting on the MFD
Phone works... much the same as any other BT feature. its alright.. people say it sounds tinny but thats no different to the others
the knobs on the previous chinese aftermarket where chrome and looked nice. these are just dull silver and feel loose
the screen is bigger
AM/FM reception is great. the previous owner had a farka to antenna plug already. so... no need to just have the one arial plugged in.
the AV IN/out I hadnt plugged in yet . not untill i find someone brave enough to install the rearview camera
there is ALOT of cabelling shoved under the top flip box. and the box dosnt work... great and smooth... it still opens and shuts but it takes some persuaion. i drilled 2 holes into the bottom and ran the ipod and USB in there. looks neat
all in all.. .its early days. but 8/10
the units could always run faster. thats my biggest beef. on my 10 year old camry with its factory nav. there was no delay switching between satnav and radio etc. no load time either.. but. hey what can you do
