Is the GPS antenna in the position I recommended or is it still just below the air vents? If the GPS is locking on properly, there should be no issue with speed reading. Mine works perfectly fine, and I always rely on it rather than the slower VW speedo.
Also GPS software has an auto start function, it's under setup -> system I think. I'm sure I mentioned it somewhere in my instructions, but I will go check later.
